Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-04-2014, 01:25 PM   #1
GRADYS Performance
GRADYS Performance's Avatar
98 S10 cruise control
What parts are needed to add a factory cruise control to a 1998 S10 with a 4Cyl and 4L60E?
GRADYS Performance is offline   Reply With Quote
Old 02-04-2014, 07:19 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 98 S10 cruise control
You'll need several items. Aftermarket kits would probably easier to install. Try looking at a unit from www.rostra.com. I have one in my '83 C10. It works great. If you don't prefer a switch on the column, there some with a pad you can glue to the bezel.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-05-2014, 11:32 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
You will need the multifunction switch and the servo/cable assembly. All the wiring is already on the vehicle. You may need to have the PCM reprogrammed.
95 S_Trucker is offline   Reply With Quote
Old 02-07-2014, 10:05 AM   #4
GRADYS Performance
Are these pieces able to be transfered from another truck? What is the multifunction switch? Is that the switch on the steeering column?
Old 02-15-2014, 07:18 PM   #5
95 S_Trucker
Yes. The multifunction switch does wipers, turn signals, hi/lo beams, hazards and cruise control. I would recommend getting the parts from the same year truck you have.
Old 02-18-2014, 12:57 PM   #6
GRADYS Performance
I would be interested if anyone has these factory cruise control parts available.
Old 02-22-2014, 08:56 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
1998 cruise control is run by the PCM.
aftermarket may be easier
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Thread Tools
Display Modes
