Old 02-26-2014, 06:56 PM   #1
Calvin D.
Active Member
Calvin D.'s Avatar
I6 and V8 perches Info
This info may have been posted already , I been doing searches on this info for my swap and thought it needed to be posted.
http://www.persh.org/pickup/perches.htm
Calvin
69 SWB Stepside I6 3OTT
Soon to be LS1 5.7
66 Impala SS Conv. 396
71 Nova LT1
71 Camaro soon to be LQ4 6.0L
Calvin D. is offline   Reply With Quote
Old 02-26-2014, 10:52 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: I6 and V8 perches Info
If I read it right on, you are doing a swap on a 69 truck? to add a little info, the 67 -72 trucks had a little different deal on the engine stands? Straight/square, altho the early trucks did use the same stands , for the I 6 230/250,& the sb, the 67-72 trucks did have a different set, for sb/I6/, or BB. From I 6, to sb spot on the engine, is 3 1/2" difference, with the I 6 stands setting to the rear. Manny guys will miss this figure, as the bolt holes are exactly 2 1/2" on the top of the frame.....the shape of the stands are different, & this makes up the other inch Any ?, lay it back....or shoot me a PM? You have a lot of good info going On the early trucks, Captian Fab, or Tex firefighter can tell you more....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-27-2014, 09:53 AM   #3
Matt Cramer
On a '67-'72 truck, you can use the perches in the six cylinder location with set-forward LSx mounts to put the engine in the stock location. Trouble is, the bump that sticks up on the mounts is likely to hit the exhaust manifolds; on my swap, I had to cut up the stands, flip the bumped-up parts upside down and side to side, and weld them back in to get enough clearance.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Thread Tools
Display Modes
