Old 03-02-2014, 05:55 PM   #1
Gmcfolife
Gmcfolife's Avatar
Will these wheels work?
I've been looking for factory wheels for my 68 6 lug GMC that will work with a 10 1/8" hub cap and disc brakes. I found these on CL. Will they work?
http://sandiego.craigslist.org/csd/ptd/4353197833.html
Gmcfolife is offline   Reply With Quote
Old 03-02-2014, 06:41 PM   #2
Omaha68C10
Re: Will these wheels work?
I do not think they will, you need the wheels with the four nubs on them where the hub cap attaches. The ones pictured are 3 nub ones, I would not use split rims on anything but low speed farm equipment anyways.
Omaha68C10 is offline   Reply With Quote
Old 03-02-2014, 06:41 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by omaha68c10 View Post
i do not think they will, you need the wheels with the four nubs on them where the hub cap attaches. The ones pictured are 3 nub ones, i would not use split rims on anything but low speed farm equipment anyways.
x2
WIDESIDE72 is offline   Reply With Quote
Old 03-02-2014, 06:47 PM   #4
Gmcfolife
Gmcfolife's Avatar
How about these wheels?
http://sandiego.craigslist.org/ssd/pts/4354226457.html
Old 03-02-2014, 07:17 PM   #5
Omaha68C10
I am going to say no, because he is also selling the front drum brake set up off the truck also which means those are probably 3 nub wheels. I would need to see a pic with out the hub caps on them to know for sure.
Old 03-02-2014, 07:20 PM   #6
Gmcfolife
Gmcfolife's Avatar
So your saying I need to find wheels with 4 nubs and 4 nubs means they will work with disc brakes?
Old 03-02-2014, 07:27 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
yes
Keith
Convert to disc brakes.
Old 03-02-2014, 07:28 PM   #8
lolife99
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=560599
Keith
Old 03-02-2014, 09:42 PM   #9
Gmcfolife
Gmcfolife's Avatar
I found these online. Are these correct?
http://www.wheelsandcaps.com/p-52387...-15x6-942.aspx
Old 03-02-2014, 10:19 PM   #10
jocko
jocko's Avatar
Since they seem to be listed as compatible with 73 and up (why they are not listed for 71 and up, I do not know.
If you want 6 lug rims for a truck with a db conversion, you need 71+ K10 wheels. 70 and prior C10 or K10 wheels, although 6 lug, will not clear the calipers. I'm (personally) not certain where the transition from 3 to 4 nub occurred. However, it's worth posting a wtb ad on here for 71+ K10 6 lugs or making a few junkyard runs - they can be found. Having said that, all the 60-66 and 67-70 folk are always scrambling for these, grab em if you can find em.
Quick question - have you already done the disk conversion? If not, you could choose a 5 lug db conversion and then an inexpensive 6-to-5 lug rear axle conversion. CPP sells those. Then you can find the 5 lug 71+ C10 truck wheels just about anywhere.
Old 03-02-2014, 10:28 PM   #11
Gmcfolife
Gmcfolife's Avatar
I already have 6 lug disc brakes. So what exactly should I be looking for because I keep getting mixed answers?
Old 03-02-2014, 11:04 PM   #12
Gmcfolife
Gmcfolife's Avatar
yes
Do you think theses are correct?
Old 03-02-2014, 11:24 PM   #13
jocko
jocko's Avatar
The answer is a 6x5.5 wheel that was made for a 71+ K10 (or K5) - and that appears to be what you've found in the link you posted. The nubs will be correct if you find 'THAT' wheel. I would not reference the picture in the link you posted, or count nubs, it says right below the image that it is only a representative photo. The application seems to be correct for the matches that are listed below the picture, so, yes, I think the wheels you posted in the above link will work. Note they have a guarantee, so perhaps only ship one and make sure it fits before paying for shipping on them all. I believe those are correct for what you are looking for. Are your disk brake calipers stock size? If larger aftermarket, there may still be interference.
Old 03-02-2014, 11:27 PM   #14
Gmcfolife
Gmcfolife's Avatar
I have stock size. Thank you for your help. I'll go with your idea and order one.
Old 03-02-2014, 11:43 PM   #15
jocko
jocko's Avatar
you betcha, hope they work out. One other source I've used is these guys - http://www.originalwheels.com/chevro...0rims-1972.php The 2nd wheel shown is what I'd expected to see listed for this stock application (i.e. 71-87 vice 73+ because the cut in for the new 6 lug wheel was in 71). Anyway, I think either place will work. And the ones you found are less expensive, a better option especially if you're gonna blast and pc the wheels. No need to pay for paint that will be stripped. For what it's worth - these guys list the exact same part number (939) for the 73 K10s also (not just 72s), so pretty sure you're good to go either way.
They don't always have stuff in stock, but if they do, they are very reliable, and they ship at $25/wheel. I made the trip to see them to save $100 shipping... But I've been there twice.
Old 03-03-2014, 03:40 PM   #16
Gmcfolife
Gmcfolife's Avatar
I found this one on eBay. There are others on there and want to make sure they are correct.
73-82 83 84 85 86 87 CHEVY 10 PICKUP WHEEL 4X4 15X6 1/8 OFFSET
http://bit.ly/1pW8epQ
Old 03-05-2014, 04:35 PM   #17
jocko
jocko's Avatar
I saw those too - I mean I saw a 1/8" o/s version available SOMEwhere. I'd personally go with stock o/s if you are using stock steelies to be safe.
Old 03-05-2014, 04:44 PM   #18
Gmcfolife
Gmcfolife's Avatar
What exactly is the 1/8" off set and how different is it to the stock?
Thread Tools
Display Modes
