and a few others
Bench bleeding master cylinder ~ what's changed?
It used to be when you bought a new or reman master cylinder you'd get plastic fittings with return tubes. Now, I see you get plugs?
The plugs seemed to work on the last one I did, but....
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Re: Bench bleeding master cylinder ~ what's changed?
I wondered the same thing on the last one I purchased. I just used an old set-up w/the return lines that I kept.
It's been a few years since the fittings and hoses have come with the reman master. Now they sell them, revenue enhancement. Last time I bleed a master I used the syringe method, was a lot easier.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
low n' slo
![]() Join Date: Mar 2009
yup..mine came with nothing to bleed it with
this is what i used to bleed the system.. ![]() http://www.oreillyauto.com/site/c/de...0678&ppt=C0067
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Thread Tools | |
Display Modes | |
