new ball joint
thanks for look at this for me
69 step side http://67-72chevytrucks.com/vboard/s...d.php?t=613407 |
Re: new ball joint
second round of pics
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: new ball joint
That looks about right.
The castle nut should thread on and line up with the hole in the balljoint. It will look different with the rubber boot on.
Re: new ball joint
Is there a part number on the spindle?
Re: new ball joint
thanks I see what they did now haha so I need new tie rod ends for 73 on now is that right?
Re: new ball joint
thanks for all you help, that really gets me that they do that kind of stuff, but I have gone to far now
Re: new ball joint
What does the UPPER balljoint say?
73-87? 71-72 and 73-87 use the same lower balljoint. But they use a different upper balljoint. There is more PROFIT using the cheaper 73-87 balljoints.
Re: new ball joint
when I called them last week and told them I had the wrong numbers on them,they told me the numbers didn't mean anything because they are all the same just drill different, B.S. they will get no more money from me. Mine are CP4S4 which says 73-87 on their web site
Re: new ball joint
uppers
#10 | |
Re: new ball joint
Because they sell the correct spindle for your truck,... for the same price. CP4S2 1963-70 C-10 2” drop $239/pr
Re: new ball joint
And Summit Racing sells them for $228.97 with FREE SHIPPING.
http://www.summitracing.com/parts/clp-cp4s2
Re: new ball joint
sorry I forgot to tell youI have 71-72 suspension on my 69........ I guess I will just try and install and see what happen the upper are for 71-72 ..... I'm confused by all this BS . the moogs didn't seem to fit ay all ,they had big gaps at the top and bottom and wouldn't even set on the dust covers. Thanks for you help man
#13 |
Re: new ball joint
The upper is definitely a 71-72 only balljoint.
If they fit,... it's a 71-72 drop spindle. Your Moog balljoints must have been 63-70 uppers. They are smaller in diameter. Balljoints have to match the spindle you are using.
#14 |
Re: new ball joint
the pic shows the new upper and the moog upper......... I'm not sure . it sure looked wrong as rain when I installed it. I will reinstall tomorrow and post pics, thanks again for your help
Thread Tools | |
Display Modes | |
