03-09-2014, 09:59 AM | #1 |
Cool Truck
Electronic Flasher ground
I got an electronic flasher because I am going to be switching all my lights out for LEDs and I was just curious as to where everyone has grounded out their flasher?
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed Last edited by Mayo; 03-09-2014 at 06:17 PM. |
03-09-2014, 10:20 AM | #2 |
Re: Electronic Flasher ground
All flashers I have used don't need to be grounded.
03-11-2014, 08:44 PM | #3 |
Cool Truck
Bump
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
03-11-2014, 09:30 PM | #4 | |
The Older Generation
I grounded mine to the screw that holds the fuse block to the firewall. LockDoc
03-12-2014, 04:21 PM | #5 |
Cool Truck
Thats a good idea, thanks for the info
03-12-2014, 08:54 PM | #6 |
"Question? 'Where did u get your elect. flasher from, and does that cure the blinker issue? I have already purchased the LEDs to go all the way around, but have not got the flasher resistors yet because I did'nt like the idea of putting a in-line resistor on all 4 blinkers. I have the full LED taillights installed already and the blinkers just go bright and stay that way until I release the turn signal lever. I have been searching for a "flasher", or "relay" to fix the issue "all in one" and I hope this is it. John
72 C/10, LWB, 5.7, Auto, with A/C F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
03-13-2014, 04:36 PM | #7 |
Cool Truck
03-13-2014, 07:13 PM | #8 |
I have looked at that before and there's not much in the detailed description of it. I wasn't quite sure if I still needed the resistors at the turn signals due to the lower voltage. Thank you for answering my question, I'll be ordering it Friday. When you mount your ground, if you could post a pic or too it would be great. On another note: I see your down in Anne Arundle county area, I'm about 30 mins NW of you, just over the Carroll/Baltimore county line. If you need an extra hand anytime, just PM me , I'd be happy to help fellow board member. John
03-15-2014, 04:01 PM | #9 |
Cool Truck
As far as I know you don't need any resistors using that flasher.
Its always good to see another Maryland member on here. I'm not sure if you know about the Maryland section on here but its a great way to find local events.
03-16-2014, 12:21 AM | #10 |
There's a Maryland Section??? WOW I'm still learning my way around on here, love the site, lotsa great help and everyone I've chatted with has been very nice and helpful. If its not too much trouble, could you guide me too this Maryland Section. oh I asked a fellow restoration tech about the flasher, resistor question, he said that the flasher is all we need, it does the job of 8 separate resistors
03-16-2014, 02:33 AM | #11 |
Maryland section: http://67-72chevytrucks.com/vboard/f...play.php?f=116
The electronic flashers are plug & play. There's no need for any additional grounding or relays. Simply remove the standard flasher, plug in the electronic flasher. Easy peasy, bosom squeezy! |
03-16-2014, 07:56 AM | #12 |
Old member
When I went full LED's I had to get the grounded flashers so they would work.
Mine is grounded to the bolt to the left of fuse block. I think it's for the e-brake in my 71. I can snap a picture tonight for you.
03-16-2014, 12:17 PM | #13 | |
There are a LOT of different Forums on this board. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll through all of the different Forums in the window that pops up.... LockDoc
Thread Tools | |
Display Modes | |
