03-11-2014, 05:24 AM | #1 |
serpentine system question
Going this route with the serpentine system.
Go used or new?....ac system whats everyone's opinion? http://www.jegs.com/p/Chevrolet-Perf...52514/10002/-1 |
03-11-2014, 06:20 AM | #2 |
Watch out for your cornhole !
Re: serpentine system question
I'd go used off a junkyard truck or van. The new kit is nice in that it gets you a new belt and water pump and a reman alternator, but that would sting me buying new pulleys and brackets when used will do just as well.
I'd bet I could buy a used setup from a junkyard, have all the parts powdercoated, buy a new water pump and reman alternator and belt and tensioner and still come out at less than half what they're asking for that new kit.
03-11-2014, 07:13 AM | #3 |
BAD BOW-Silverado XST
Ditch the right side bracket. Get one off a truck. A 93?-95 truck. Truck brackets don't have provisions for a smog pump. I bought a bracket for a 94 truck. It looks so much cleaner. Smaller belt and one less pulley. The compressor is not best for A/C. I would replace it with a Saden version. There are brackets to make it fit. On used versions, be sure to get the V8 crank pulley. You can use your steering pump. Just swap pulleys. Used is a less expensive option if done right. New water pump is cheap. The alternator and compressor are the expensive parts. You can fit an AD144 alternator instead. 144 amps is better than 100 on power options. My door locks pop like crazy with 144 alternator.
03-11-2014, 07:58 AM | #4 |
Frequent Flyer
I have the stock setup off a early to mid 90's truck as well.
Mine is the earlier design with the metal bracket instead of the aluminum one. And don't forget you will need a reverse rotation water pump if you convert to a later model OEM system. |
03-11-2014, 07:59 AM | #5 |
Getting Old; Going Broke
Holy bat turds... Makes me wanna rethink my prices.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
03-11-2014, 09:13 AM | #6 |
OH, yea. You have to find a way to support the water hose!! It's long!! I had a bracket maded to hold up mine. JWall routed his behind the alternator.
03-11-2014, 09:40 AM | #7 |
Reverse rotation water pump... upper radiator hose brace... and.... if using a manual fan set-up, a reverse roration fan.
03-11-2014, 09:42 AM | #8 |
Slots go on anything!
You can almost buy a whole Suburban on CL to rob the serpentine system off of for that price.
1974 Jimmy- 5.3/4L80e/NP241 |
03-11-2014, 09:58 AM | #9 |
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 03-11-2014 at 10:04 AM. |
03-11-2014, 10:35 AM | #10 |
What kinda set up is that? Could you give us more info on it?Looks like the a/c bracket is there, but the a/c is t installed, right?
03-11-2014, 11:17 AM | #11 |
correct this is the a/c bracket without the smog pump. I believe i got these off a 96 truck. My pops truck is a non a/c truck getting vintage air later on.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
03-11-2014, 11:30 AM | #12 | |
-W |
03-11-2014, 11:31 AM | #13 |
I like the 3rd gen F body stuff, there's even a simple way to run a vacuum pump where the original air pump was
03-11-2014, 12:23 PM | #14 |
If im not mistaken, 4.3 v6's serpentine systems will work on a sbc.
03-11-2014, 12:54 PM | #15 |
Correct. They also come with & w/o the smog pump like the 1/2 ton trucks. As mentioned, the smog pump space can be utilized for alternative pumps if desired or look for the non-smog brackets for a cleaner (my opinion ) look.
03-11-2014, 01:48 PM | #16 |
If you use a V6 setup on a V8, you have to find a V8 crankshaft pulley and a couple of the little support rods that go to the intake manifold are V8 specific too.
03-11-2014, 02:36 PM | #17 |
What was different about the crank pulleys?
03-11-2014, 03:29 PM | #18 |
The 4.3 uses a little thin harmonic balancer and a correspondingly deeper pulley. When you bolt that pulley to a typical thick 8 inch SBC balancer, the belt surface is too far out.
This experience applied to my 92 C1500 which I swapped 4.3 to 5.7. It could have been an isolated case and not across the board. I do not know for sure.
03-11-2014, 04:54 PM | #19 |
I used a V6 set up too. I had to find a V8 crank to align the belt.
03-11-2014, 05:51 PM | #20 | |
I know the kit I used utilizes a spacer on the crank pulley. I'll have to dig back through my literature & see if I sourced a sbc lower pulley from somewhere (I might have & don't remember ).
03-11-2014, 06:44 PM | #21 | |
Did I do something wrong mine was like 85 plus powder coat and water pump |
03-11-2014, 10:36 PM | #22 |
In addition to the water pump, add in the price of a new a/c comp, alt, power steering pump, fan clutch + fan, tensioner, & belt (unless you have all that stuff conveniently lying around). I would imagine that's some of the cost difference.
03-11-2014, 10:38 PM | #23 | |
My compressor came from Vintage Air. |
03-11-2014, 10:40 PM | #24 |
03-11-2014, 10:53 PM | #25 | |
If there's alot of wiggle room, I wouldn't worry. If it's tight.... I would do some sort of anchor/brace to keep the hose from shifting.
Thread Tools | |
Display Modes | |
