factory tach
I'm putting in a factory tach in my nontach cluster and I have an old cluster with a tach in it. Is there a wiring harness used for that or do i just have to wire it myself?
Re: factory tach
subscribed
Figure out what you want--then figure out what you are willing to give up to get it. |
![]() Join Date: Oct 2011
Re: factory tach
Ok, to answer your basic question...there is a (simple) tach wiring harness for the tach. However, it is not overly difficult to reproduce. Basically you need 1 wire to go from the signal terminal on the tach to the - (negative) on the distributor. Then you need one to go from the other terminal on the tach to a main power (+) in the fuse box. Then the whole thing needs a good ground.
That said....do you have just the tachometer head? or do you have the whole needed and required 'kit' for the factory tach? The 'kit' should include the tach based inner and outer gauge plates (to replace the original ones), the new 'tach' based lens and the larger printed circuit. any more info on what you have? Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: factory tach
I have the printed circuit on the other cluster that i have which has the factory tach in it so it should be able to use the circuit board, the tach, and all the guts out the old one I have and use that one right? The reason I'm not using the tached cluster is the front of the cluster doesn't look to good
Re: factory tach
Tom is reproducing the tach harness for points or HEI and in custom lengths too.
Additionally he builds clusters to spec. and offers rebuild/ modifications of your existing cluster plus parts support. http://67-72chevytrucks.com/vboard/s....php?p=6568267
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thread Tools | |
Display Modes | |
