03-15-2014, 05:33 PM | #1 |
Wilwood Master Cylinder
I believe my master cylinder on my 71 C10 is on its way out the door, but I know that if I replace it with another factory unit it will get covered in surface rust like all factory units. To avoid the rust and maybe get a little more stopping power I am considering a polished aluminum Wilwood unit. Has anyone used one of these? How well does it fit? How would it hold up to the elements?
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
03-15-2014, 05:58 PM | #2 |
Re: Wilwood Master Cylinder
Honestly, I just put a good coat on engine paint on my factory one, if you want to keep the factory look duplicolor has cast metal colored paint. Holds up well until you spill brake fluid on it
71 K20 64 GMC mud truck |
03-15-2014, 07:53 PM | #3 |
Wilwood also sells a tandem style with a plastic hopper on the top with screw on caps. Much easier to keep fluid inside. All aluminum body. Not sure what kind of project your working on, but you can cross this style Wilwood with a Chrysler from your local Advance Auto--Part# 13-1983..$37 vs $105..just an idea
03-15-2014, 08:18 PM | #4 |
The Chrysler unit is an interesting idea. I just need to decide if I like the look of the plastic reservoir.
03-17-2014, 11:12 AM | #5 |
Here's mine. Its a 1 1/8 bore to go with power brakes. I also went with the wilwood because the lid screws down. I haven't had any leaks with it unlike the unit I replaced it with that always seemed to leak.
03-17-2014, 11:30 AM | #6 |
I think I am going to try out the Chrysler unit first since its so cheap.
03-17-2014, 03:26 PM | #7 |
Does anyone know the distance between the mounting holes on a stock master cylinder. I'm at work and would like to compare it to the Chrysler unit.
03-17-2014, 04:23 PM | #8 |
3.4"
03-17-2014, 04:40 PM | #9 |
03-17-2014, 04:56 PM | #10 |
I can't tell you if that Chrysler master will work or will fit your truck but it's $27.79 on Rock Auto
03-17-2014, 05:07 PM | #11 |
I would for Advance so its almost always cheaper for me to get it here. Rock Auto charges quite a bit for shipping. But thanks for the heads up.
03-17-2014, 11:25 PM | #12 |
hey dream, u will have to make the mounting holes on the wildwood unit a little wider. I'll try and attach a photo of mine. I just mounted it this past weekend.
03-17-2014, 11:29 PM | #13 | |
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
03-18-2014, 12:46 AM | #14 |
I take it that the Chrysler set up is for manual brakes, what about power brakes
03-18-2014, 12:56 AM | #15 |
Bolt it to a booster or hydro boost
03-18-2014, 06:36 PM | #16 |
mg, that's exactly right...I was referring to the Chrysler part, not the actual wildwood..thanks for clarifying.
03-21-2014, 01:27 PM | #17 |
Does anyone know what size nut goes into the distribution block?
03-21-2014, 06:28 PM | #18 |
master cylinder uses 3/8-24 line nuts if that is what your referring to..the threads are cut pretty deep and I'm using the longer nut in order to make sure my flare bottoms out and seals correctly..
03-21-2014, 06:59 PM | #19 |
I was asking about the ones that go into the distribution block, but I believe they are the same size as the ones in the mastr cylinder.
03-22-2014, 02:50 PM | #20 | |
03-22-2014, 07:49 PM | #21 |
no, I didn't have to adjust the pedal rod..i'm using a hydroboost booster
03-22-2014, 07:58 PM | #22 |
It looks like the pedal is fine but the master cylinder will mot move fluid for anything. I'm guessing its a bed unit.
Thread Tools | |
Display Modes | |
