Old 03-16-2014, 07:07 PM   #1
67stepper
67stepper's Avatar
Best deal on front lowering spindles
So far the best i can find is at summit racing $229.00 and free shipping
Part cpp-cp-4s3
2.5 in lowering correct?
But my question is cp4s3 the old style or new that moves in 3/4" to allow for wider tires? i want to keep my 255/60/15 on the front.
I also want to stay 6 lug front disk and the best deal is $89.00 part #03-6370-6l at ECE or CPP.
Any better deals out there?
67stepper is offline   Reply With Quote
Old 03-19-2014, 07:40 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Best deal on front lowering spindles
I don't think it's ever been proven how much the CPP Modular spindles move the wheels in.
Never could get an answer to this question when CPP had a Vendor on here.
Plus,... moved in compared to what?
1) drum brakes?
2) stock disc brakes? (which we know are 3/4" wider than drum brakes)
3) other manufacturer's drop spindles?
Just saying,... don't count on the 3/4" measurement you mentioned in your post.
Keith
Convert to disc brakes.
Old 03-19-2014, 04:39 PM   #3
67stepper
67stepper's Avatar
Just order a set from CPP ebay store $215.00
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi.
Old 03-20-2014, 01:18 AM   #4
66 C10 383
If I'm not mistaken, the "newer" style CPP modular spindles are only 2" drop and also require a bracket not included with the spindle depending on which brake caliper you chose.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 03-20-2014, 01:31 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
These are a new version that is supposed to be 2 1/2" drop. They don't look like the modular ones I've had that required a separate bracket...these look to fit factory calipers like the mcgaughy spindles I had... Says on the ad it
"will not move the wheels out 3/4 of an inch per side like the factory disc kits do"
http://www.ebay.com/itm/73-87-CHEVY-...5ba713&vxp=mtr
The ones I linked use 73-87 ball joints/tie rods which I usually recommend as they are easier to source and generally cheaper.
VA72C10 is offline   Reply With Quote
Old 03-20-2014, 08:28 PM   #6
big d's red67
big d's red67's Avatar
1) drum brakes?
I just put a set on my 67, they moved my wheels in 1 1/8 inches per side from regular drop spindles. My track width went from 77 inches (outside of tire to outside of tire) to 74 3/4. CPP says they are 2 inch drop spindle it is close to 2 1/2 drop in reality.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Thread Tools
Display Modes
