Old 03-19-2014, 08:04 AM   #1
1968BURBAN
CPP or Porterbult opinions air ride
Picked up a 68 GMC Suburban. Looking to lower with air ride and was looking for some opinions. Here is my thoughts.
Currently running 29" tires on 15" wheels. For the rear going to C-notch, change trailing arm crossmember, install upper shock mount bar, adjustable track bar, bags mounted to trailing arms, and maybe a 1 or 2" block, keeping stock trailing arms for now. (on budget for this year)
So... I can get the rear done with CPP stuff for quite a bit less than the Porterbuilt parts. Is there that much of a difference? I realize the PB notch looks like a better unit than the CPP but if I go CPP notch I was planning on reinforcing it some, body is off the frame right now so plenty of access to do what ever.
Thanks in advance for any opinions / advice
1968BURBAN is offline   Reply With Quote
Old 03-19-2014, 08:15 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: CPP or Porterbult opinions air ride
Porterbuilt builds the best bolt-in c-notch in my opinion.
Keith
Convert to disc brakes.
Old 03-19-2014, 08:20 AM   #3
CC69Rat
CC69Rat's Avatar
There are 17 Grade 8 bolts in the PB CNotch, upper / lower. I'd go with Porterbuilt.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-19-2014, 08:33 AM   #4
1968BURBAN
OK, I do like the construction of the PB notch, prob will go with that
What about the other components? CPP or PB front crossmember, shock mount, track bar? Trying to get it down and on the road without breaking the bank
Old 03-19-2014, 08:39 AM   #5
lolife99
lolife99's Avatar
All Porterbuilt,...
Keith
Old 03-19-2014, 08:51 AM   #6
CC69Rat
CC69Rat's Avatar
Yep - what Keith said.
Welcome to the board by the way!
Chad
Old 03-19-2014, 09:10 AM   #7
1968BURBAN
Thanks guys! Lots of info here, great forum!
Here's a pic the day I brought it home
Old 03-19-2014, 09:11 AM   #8
1968BURBAN
Old 03-19-2014, 10:21 AM   #9
lolife99
lolife99's Avatar
VERY cool 'burb!!!^^^
Keith
Old 03-19-2014, 10:27 AM   #10
1968BURBAN
Thanks, been taking some pics along the way, might do a build thread, might not. All in pieces at the moment but coming along well.
Old 03-19-2014, 10:49 AM   #11
CC69Rat
CC69Rat's Avatar
I have an extra PB upper and lower shock bar but I'm not sure if they are the same for the Burb as for the trucks (?) I'm thinking they'd be the same but I'm not sure. The lower shock bar is for use with Porterbult Trailing arms. I'd make you a deal on them if you're trying to put things together a piece-at-a-time.
The lower shock bar with stock trailing arms is different than with PB trailing arms.
I know very little about the Burb .. just saying, I'll have these for sale in the parts section soon.
Chad
Old 03-19-2014, 10:54 AM   #12
tony58
Porterbuilt all the way. Watch out for Chinese performance poop
tony58 is offline   Reply With Quote
Old 03-19-2014, 11:11 AM   #13
1968BURBAN
PM sent
Old 03-19-2014, 12:40 PM   #14
Bigdav160
Bigdav160's Avatar
I'd drive it and not change a thing
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-20-2014, 09:48 PM   #15
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
sweet ride
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-20-2014, 10:55 PM   #16
Hart_Rod
Hart_Rod's Avatar
Nice.
Hart_Rod is offline   Reply With Quote
Old 03-21-2014, 02:04 PM   #17
Number98
Prestige Worldwide
Number98's Avatar
Just keep in mind that the Porterbuilt C-notch has fasteners on the top of the frame rail, these will be tough or nearly impossible to get to with the rear floor in. Having said that, I think that Porterbuilt will be the highest quality pieces you can get...period!
Number98 is offline   Reply With Quote
Old 03-21-2014, 07:31 PM   #18
uncle
Slick Burb and 68 and gmc and black. Tell me the inside is not red.
uncle is offline   Reply With Quote
Old 03-21-2014, 09:32 PM   #19
Number98
Prestige Worldwide
Number98's Avatar
You have enough vehicles laying around......
Old 03-21-2014, 09:37 PM   #20
uncle
I'd probably swap a couple for that cream puff if it's as clean as it looks.
Old 03-24-2014, 10:52 PM   #21
Hart_Rod
Hart_Rod's Avatar
Nice burb!
Old 03-25-2014, 11:46 AM   #22
1968BURBAN
Thanks guys! Inside is black with red door panels. Going Porterbuilt for rear suspension. Just a little confused why "others" push the trailing arm crossmembers so much. Talked to Dave at PB and he said I can run the stock unit. I realize the stock unit hangs lower than the frame but what about geometery changes after going down 6+ inches?
PB told me I would have to have modify my 2 pc driveshaft to use their crossmember, so if I go that route Im going to wait till I decide if a 5.3 swap is in order.
Also as mentioned above, PB notch would require floor removal but already have body off the frame for a little clean up at the same time.
Old 04-03-2014, 01:09 AM   #23
sduckworth13
sduckworth13's Avatar
The reason everyone pushes the PB trailing arm crossmember is it allows you to adjust your trailing arm angle and run the exhaust up thru the crossmember and between the frame rails.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-03-2014, 07:38 AM   #24
72freak
Rottenwood Garage Member
72freak's Avatar
I looks like everyone has the correct answer and none have mentioned the most common reason. Look at all the complaints about products and customer service about CPP over the years. The internet if full of bad CPP press. I would use anything but them. I will have to admit I have never had any personal dealing with them (for that very reason)but one of the Rottenwood Garage members did buy a disc brake drop kit from them that we had to grind on to make it work.
Porterbult all the way!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 04-03-2014, 07:51 AM   #25
CC69Rat
CC69Rat's Avatar
If you do decide to go with PB stuff, give Travis a shout at Pro Performance. He is a forum member and keeps PB in stock. Cool guy too and he'll work with you.
Chad
Thread Tools
Display Modes
