4l80e installed pics, help!!!
So I have a 69 c10, I really want to run the Scotts under cab break kit (already purchased) but I am hesitating about revamping my break system. The bracket they have sold me is pretty badass, its gorgeous. The only reason I am hesitating, is because I am planning to go lq9/4l80e. I need a under shot of the 4l80e sitting to see if there is even enough room to run Scotts set up. I need to know how much room is between the trans and the frame rail so if any one could measure i would love it. Also i will have to route my exhaust somehow so its a pretty big deal for that as well.... PLEASE HELP A FUTURE 6.0 C10
Unless some one has already done this and can supply pics that would be a dream come true haha Jordan
1966 Long Bed step side 4 on the floor 1969 Shortbed 1995 Mazda Rx7 Sanderson Roofing and Gutters |
![]() Join Date: Apr 2005
Re: 4l80e installed pics, help!!!
I'm not 100% positive, but I don't think you will have room. I've included a couple different chassis pictures, and as you can see it would be tight to do that, but I guess anything is possible with enough fab work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Wow, trans is beefier than I knew. I mean I read how much more they were than the 60s but I had not seen a under shot like this... well maybe ill throw the bracket in my closet and wait to swap and see how it sits. Ill leave it on the fire wall for now and install the rest of the Scotts parts I have...
Boosted Member
Hopefully along with HartRod's pics, these will help you out.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Ok, it does not seem unrealistic at all. Maybe i could notch the frame out a bit just to create a path for the exhaust to run...
I talked to Justin and he says it won't be a problem, but will be a tight fit. Thats perfectly fine for me.
#7 | |
Boosted Member
Old member
Here are some of mine. 4L80E with pipes ran 2.5" It's pretty tight on the drivers side for sure. I'm running the B&M shifter cable on mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I know its not the question the OP asked (and not trying to highjack) does anyone have a pic of the height of the oil pan vs the tranny pan? Which one hangs lower?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Depends on which oil pan you are running. The truck pan hungs lower. The Fbody pan is about level.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-24-2014 at 08:11 PM. |
Old member
The pictures are of a truck oil pan.
#13 |
Boosted Member
Here's mine with a deep B&M pan on the 80e, and an F-body pan.
Truck pans are bad, mmmmmkay? Busted mine open twice on my bagged C-10, lol. ![]()
#14 |
Thanks for the info!
Thread Tools | |
Display Modes | |
