03-21-2014, 11:18 AM | #1 |
16 vs. 16.5 rims
Hey Fellas, I have always ran 16 inch rims, and have a chance to score a deal on tires and wheels, but they are 16.5's. I am pretty sure it matters very little, but would like to make sure. Any considerations I am missing?
03-21-2014, 11:25 AM | #2 |
Re: 16 vs. 16.5 rims
Depends on how you are going to use the truck. The 16.5 are very limited in what you can get for tires.
Not to mention, they're usually very expensive when compared to their 16" counterpart. Just some food for thought. |
03-21-2014, 12:16 PM | #3 |
Another Day, Another Dollar
Avoid 16.5's. they're an old school size and like the guy above me said there's not many tire choices out there. Interco is the only manufacturer that I know of that still makes a DECENT selection and they're mostly aggressive off road tires. I have also heard that you can squeeze 16's onto a 16.5 rim but its ill advised and you probably have to know somebody with a tire machine to have it done.
How do I know all of this? I'm running 16.5's on my truck
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
03-21-2014, 12:37 PM | #4 |
Wow, I just checked Tire Rack. 75 options in a 265/ 75 R16. 0 in a 16.5
Same story when went up to a 285/75. Is the 16.5 designed for a much bigger tire? The ones that are on the rims I am considering are 33's. Any insights? |
03-21-2014, 01:44 PM | #5 |
1st.off...DO NOT mount a 16" tire on a 16.5 rim!!!! 16.5 rims do not have a safety bead built in that will not allow u to lower air pressures on off-road use! N like others have said...16.5 tires r limited avail..I'd go 16" if I was buying tires n rims!
03-21-2014, 01:51 PM | #6 |
16.5's are a heavier weight rating load bearing design for stiff sidewall tires. A tapered type bead that holds the seal from pressure alone thus requiring more air pressure to maintain the bead seal. They are ok if you have a camper or on a tow truck but as said very few designs for replacement tires.
OH Yeah! What 66crewcab said about squeezing a 16 on a 16.5... won't work even if you did try it and someone would prolly get killed. Many warnings sent out when I was a tire jockey back in the day. Carnage was not pretty.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-21-2014, 07:39 PM | #7 |
I'm running 16.5 35s on my 86. Just put them on this winter,tires are BFG all terrains. Yes,like others said you are really limited for choice on 16.5s.I got the rims for next to nothing,so that's why I'm running these.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
03-21-2014, 10:04 PM | #8 |
Don't get them unless you like Interco's selection of agressive tires, or like the BFG all terrain(and they only produce those in batches).
The last time my friend bought tires for his Super Duty with 16.5s, he ended up with 33X12.50 All Terrains that had to come from four different locations across the country. |
03-22-2014, 12:54 AM | #9 | |
03-24-2014, 02:19 PM | #10 |
That's sound advice all the way around--think I am going to pass on this deal. Thanks fellas.
03-24-2014, 02:28 PM | #11 | |
Thread Tools | |
Display Modes | |
