Old 03-23-2014, 12:18 PM   #1
crossland1962
crossland1962's Avatar
62 c10 Step Notch Question
Has anyone purchased a step notch that will work for the 60-62 frames? I cant find anything for these frames! I have been told that a s-10 notch will work because their frames are straight from the cab back. Any help would be appreciated! Pics if available please.
crossland1962 is offline   Reply With Quote
Old 03-23-2014, 06:41 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 62 c10 Step Notch Question
PorterBuilt has them for this frame.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-23-2014, 08:26 PM   #3
crossland1962
They go from 59 to 63. Any other suggestions??
Old 03-23-2014, 08:27 PM   #4
crossland1962
Build them is my only option it looks like!
Old 03-23-2014, 09:32 PM   #5
LVPhotos
LVPhotos's Avatar
Nate builds them with the unique frame curve. They will be open tomorrow. I checked in on all things for my 62. They built a front crossmember and some longer trailing arms for me. I also got panhard bar kit from them
Old 03-23-2014, 09:56 PM   #6
crossland1962
Nate?? The frame on the 62 isnt curved its straight thats why 63 up wont work. Did you fab yours or use his notch?
Old 03-23-2014, 10:40 PM   #7
LVPhotos
LVPhotos's Avatar
I am not going to go past fender and bed wood so I plan to install pipe notch I cut from 5" pipe. Nate from PorterBuilt has notches for these frames. For some reason not all parts ended on new web page.
They do have weld in notches not found on page. There are mild 4" and the larger extreme that are 6". Call and find what is needed. I have had everything built for the 62 from them.
Old 03-23-2014, 11:21 PM   #8
crossland1962
thanks for the info! i will give them a call!
Thread Tools
Display Modes
