Old 03-23-2014, 09:15 PM   #1
cjohnson6772
cjohnson6772's Avatar
Dropped Spindles - 3-3/4" Backspacing 15" Wheels
I know the topic has been discussed a good bit, but I have never seen a definitive answer for 3-3/4" backspacing.
I have 15"x8.5" American Racing 200s wheels. Looking to install drop spindles and I'm hoping I won't have to trim the lower control arm. I've seen some people say anything under 4" backspacing was ok. I've also seen people say 3.5" is max. Anybody ever tried 3.75" backspacing 15" wheels? Any spindles any better than the new CPP CP4S3?
cjohnson6772 is offline   Reply With Quote
Old 03-23-2014, 09:43 PM   #2
67stepper
67stepper's Avatar
Re: Dropped Spindles - 3-3/4" Backspacing 15" Wheels
My spindles should arrive this week and my wheels are 15x8.5 with 3.5backspacing. So if your not in a hurry ill let you know by the end of the week.
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi.
67stepper is offline   Reply With Quote
Old 03-23-2014, 10:03 PM   #3
cjohnson6772
Sounds good. I've replied to your other thread so I will see the update if you post on this thread or the other. I know the backspacing is the make or break, but 8.5" and 3.5" bs should give a pretty good idea. I really just want to lower the front a small amount and not give up any spring height
Old 03-25-2014, 03:38 PM   #4
68Stepbed
68Stepbed's Avatar
They'll fit fine. I had 15x8's on mine with 3.75" bs when I first lowered it. No issues.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-25-2014, 04:03 PM   #5
cjohnson6772
What brand? You are the man for having a definitive answer btw. And I have always loved your truck
Old 03-26-2014, 03:58 PM   #6
68Stepbed
68Stepbed's Avatar
I had American Racing Hopsters. This pic is with 15x8 on all corners with 255/60/15 F 275/60/15 R on a 3.5/5 drop.
Matt
Old 03-26-2014, 04:53 PM   #7
I feel Early Classic parts are second to none.They are the Mack Daddy.
Old 03-26-2014, 05:13 PM   #8
BugzC10
BugzC10's Avatar
You shouldn't have any rubbing issues with 3-3/4 BS. I had 2.5" CPP spindles with 15x10" with 4" BS...close but no rubbing on the spindle. I changed to 15x6.5 rally's with 4" BS....no rubbing. The 4.25" BS on a 15" wheel will not work without some grinding where the tie rod connects and possibly the LCA.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-26-2014, 05:30 PM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I run 8x15 rally's all four corners, 3.5 drop up front w/2.5 drop spindles & 4" lowering springs out back...275/R60-15 BFG's and 4-3/4" back spacing all four... The issues were the tire's up front when the 2" drop springs didn't allow enough clearance for the tires in turns and bumps...I raised her back up 1" by reinstalling the factory coils with 1/2 coil cut off...72 C-10 LWB 350/350tb factory 5x5's all around..."just sayin"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-26-2014, 07:11 PM   #10
cjohnson6772
Well I'm convinced. I think I am going to buy a set of spindles and give it a try. I do wonder if a stock height spring vs a dropped spring makes a difference on clearance for the LCA. My thinking is that since you guys are running a cut or lowering spring that the upper and lower control arms are "closer" therefore allowing more clearance? Idk. Gonna try some spindles. Probably ECE. Worst case I have to cut 1/2 coil to make it all fit.
Old 03-26-2014, 09:48 PM   #11
mgchevyparts
mgchevyparts's Avatar
The A arms are separated by the spindle so that never changes regardless of your coils height. The reason high offset wheels rub the LCA is the axle center has been raised by the amount of drop, usually 2.5" and that raises the rim up 2.5" and then it can hit the LCA if the back space is too much. 3 3/4" will fit fine
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 03-26-2014, 09:51 PM   #12
cjohnson6772
Thread Tools
Display Modes
