03-28-2014, 09:09 PM | #1 |
Original wheels - worth it to restore?
I've got the original steel wheels (5 of them) from my 1971 C10. (15" x 6" 5 lug I think). (They're stamped GM 71.) I've also got the original full hub caps in okay shape as well.
Would it be worthwhile to get them blasted and powder coated to put back on the truck, or would it be a better investment to find some non-stock wheels that might fit a wider range of tires? The crux of it is that I need new tires and I've got a crappy set of wheels on the truck now, so I'd like to "upgrade" the wheels and tires at the same time, but don't know jack about tires or wheels. Thanks much. Last edited by Modest_Man; 03-28-2014 at 09:14 PM. |
03-28-2014, 09:19 PM | #2 |
Re: Original wheels - worth it to restore?
Depends on what look you are going for. If you want the stock look, nothing is better than original. I ran 255/60/15's on that size wheel for a while (6 lugs on my truck), and they look and perform ok. No issues. Rim is a touch narrow, but they work fine.
Powdercoaters around me get $50/wheel, so for the brand new wheel look, thats pretty cheap. If you are going for a custom look, then its all up to you. FWIW---I dropped $150 on five 6-lug rallye's (15x8), had them powdercoated ($250), and had my tires swapped onto them ($100). Then I bought new wheel centers ($50) and trim rings ($50) on Ebay; both are cheapo repops. So, $600 later I have the look I wanted, and I have wheels that will fit when I convert to front disk brakes. It was worth it to me, but fact is you can buy some of the lower cost custom wheels for about what I spent on refurbishing and installing mine, so I probably could have had new custom wheels for around $800 or so. Its all a matter of what you want.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-28-2014, 09:27 PM | #3 |
Thanks for the insight.
I can get a set of (4) wheels blasted and coated for $125 locally here in Oregon. I'm not after any specific "look". Just going for cheap and functional. Daily driver status. If tire sizing isn't an issue on the wheels I'd definitely lean towards refurbishing the originals. That's the only thing keeping me from moving ahead. |
03-28-2014, 09:30 PM | #4 |
If it were me I would have the original wheels blasted and either painted or powdercoated.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
03-28-2014, 09:38 PM | #5 | |
Thats a good price for powdercoat. I'd jump on it.
03-28-2014, 09:48 PM | #6 |
Next question then would be what tire to go with. Are there any in particular that stand out brand wise (or size wise)?
03-28-2014, 10:14 PM | #7 |
Watch out for your cornhole !
I'd be wary of any shop that will blast and powder coat your wheels for 125.
That's about half price of going rate for a professional shop. Lots of people think that all powder coating is equal and that shopping for price is a good idea. That's very untrue. It's like a paint job, if you shop for lowest price, you're likely to be one of those people who end up complaining about how powder coating sucks.
03-28-2014, 10:23 PM | #8 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-28-2014, 10:31 PM | #9 |
I just dropped my steel rims off at schawbies, to be blasted and powerdcoated this week The estimate was for $125, and they are sending them down to a shop in oregon. Hopefully they turn out ok, i will post some pics when i get them back. If they get fubared, i guess it will be lesson learned. I didn't want to spend much on them though. My pops picked up this set of rims out of a junk yard in idaho when he owned the truck, to replace the split rims that originally came on it. Three of the four rims matched and the fourth one was off of a ford, it had a little ford stamping, that i removed with a die grinder before i dropped em off at les schwab.
1970 GMC K2500 aka MaTeR 2007 Chevy Silverado 1500HD Classic |
03-28-2014, 10:47 PM | #10 | |
I don't play around, but I'm also pretty expensive. It runs a whole or more than 25 per wheel to get top results. I finally got to where I just don't pursue doing wheels because most wheel customers just shop for price. Its pretty much only antique motorcycle parts nowadays. That's my main passion anyway and the pace of doing restoration work is more suited to me than chasing individual jobs. Good results are very much in reach but it takes a lot of attention to detail. It's not unheard of to spend two hours per wheel when doing them. There's a lot of time spent filing out gouges on the lips, deburring lug holes, chasing threads and getting that seam between the face and the barrel cleaned out beforehand.
03-28-2014, 10:53 PM | #11 |
I just picked up my wheels from the powder coater... stock steel 6 lug 15" x 6" $60 a piece powder coated white.. they are 4 nubs that will clear disks... I just checked . I am super happy with them... can't wait to tear into the truck tomorrow and start on the drop
03-28-2014, 11:38 PM | #12 | |
I was less concerned about cost than quality, but didn't want to invest both arms and a leg either. I'm heading back to him in a couple of weeks with a bunch of small parts I need done.
03-30-2014, 02:37 PM | #13 |
So what tires should I toss on stock rims?
03-30-2014, 03:59 PM | #14 |
If you go white, make sure they get all the abrasive out of the seam between rim and center ! Rust will form if not ! Ask me how I know ?
71 C-20 07 Magnum RT AWD |
03-30-2014, 04:48 PM | #15 | |
03-31-2014, 09:30 AM | #16 |
I've dealt with a metal coating outfit for 30+ years who do large production runs to a single little piece for you or I. They get $65 a wheel and it is done right. I've had so many parts done my computer would run out of ink listing them. No problem with white that I'm aware of. I had a set of 9.75 x 16.5s done in '91 for my '72 K/20 Cheyenne Super Custom Camper. In '01 I moved them to my '72 K2500 Sierra Custom Camper. I got other tires that needed 8.25s to fit right,so I sold them two years ago.
That's my 22 year old son in the first picture,next shows the wheels on the GMC in '05,next two are pictures I took when I sold them,and the last shows the 8.25 I had done and yet to install:
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-31-2014 at 09:35 AM. |
03-31-2014, 09:40 AM | #17 |
I actually first had those wheels powder coated gloss black back in the '80s when I ran them on my '84. I forgot about that. Back when I changed the color,I was having this grave stone engraver blasting my stuff. He had heck of time blasting that black off. He called me when he gave up.I suggested running a grinder across it to get a start on busting through. That worked and my wheels got turned to white for another 20+ years
04-01-2014, 09:42 PM | #18 |
I dropped them off today, I'll update when they're done. Still looking for tire recommendations for the stock wheels.
04-14-2014, 06:26 PM | #19 |
Better late than never! I picked up the wheels a week ago. Still need to go find some tires.
04-14-2014, 07:47 PM | #20 |
20' Daredevil (Ret)
Might get better tire responses in a new thread asking about tires. There are so many choices, it's a matter of what you are willing to spend and what you expect from a tire. Generally speaking, cheaper tires won't last as long as premium tires. Will you be getting stock size or maybe something larger? Highway tread or traction tires, or something in between? http://www.tirerack.com/index.jsp is a great resource for research & comparison. They are good to deal with, or you can use their prices for local price matching.
04-14-2014, 11:03 PM | #21 |
I got my wheels back last week, but was kind of lazy up loading some pics. The wheels are far from perfect, but perfect from afar. I paid 25$ per wheel, 60$ for mounting and balancing some tires i had laying around 17$ for brass valve stems. It dose look like some media was left in the nooks and cranies, oh well. Over all im happy, with the old junk yard wheels for my old junk yard truck. Oh yeah, you might notice in the pic there are only three wheels. One of the guys at swhabies put a huge gouge right in the front of the wheel. So i asked if the would send it back to be redone, which they did for free. I will be geting the fourth wheel back this week. I should have cleaned the dirt and gunk the tire guys got all over the wheel before i took the pictures.
04-14-2014, 11:08 PM | #22 |
for whatever reason the pics didn't load. here they are hopefully?
Thread Tools | |
Display Modes | |
