Old 03-30-2014, 07:04 PM   #1
64chevmn
Radiator baffles
When I bought my 64 c10 last fall, there where no side radiator baffles nor a radiator shroud. My local junk yard has a few 64-66's with baffles in place, but they appear to be all 6 cylinder trucks. Are the 6 cylinder baffles the same as the v-8's or are the different. Also, if I buy a reproduction v-8 fan shroud, do i need the baffles to mount the shroud to?
64chevmn is offline   Reply With Quote
Old 03-30-2014, 07:46 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Radiator baffles
I am baffled by the term" baffles"...perhaps you can post a pic and we can be more helpful....you know a picture is worth a thousand words.
AcampoDave is offline   Reply With Quote
Old 03-30-2014, 08:36 PM   #3
davbowen
davbowen's Avatar
the larger l6 is the same as the v8. you want the ones from a radiator that sits on top the cross member as opposed to one that sits down in the cross member.
davbowen is offline   Reply With Quote
Old 03-30-2014, 10:11 PM   #4
DPowers
DPowers's Avatar
This may help
http://67-72chevytrucks.com/vboard/s...d.php?t=614821
DPowers is offline   Reply With Quote
Old 03-31-2014, 08:39 AM   #5
64chevmn
Exactly what I was looking for...........THANKS!
Old 03-31-2014, 08:44 AM   #6
Improbcat
Improbcat's Avatar
Since the subject of baffles has come up, is there someplace to order replacements for the rubber pieces on the smaller I6 baffles? Or any suggestions of something to make them out of?
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 03-31-2014, 04:32 PM   #7
Old Bleu
Old Bleu's Avatar
I got mine from classicparts.com and was very happy with them. The originals were attached to the metal shroud with staples, but I used tiny #6 machine nuts and bolts to reattach them.
Old Bleu is offline   Reply With Quote
Old 03-31-2014, 08:25 PM   #8
Lugnutz65
Lugnutz65's Avatar
I just bought the rubber pieces from American Classic Truck Parts. I have both sizes like Sharps40 posted above.
Here's a few pics of the V8 size that is used with a short/wide Harrison radiator with radiator lower saddles on the upper part of the crossmember.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-31-2014, 08:32 PM   #9
Lugnutz65
Lugnutz65's Avatar
Here's the smaller size for the tall/narrow Harrison radiator. The Tall/narrow uses the lower saddle position and the wide/short uses the upper saddle position.
Old 03-31-2014, 08:35 PM   #10
Lugnutz65
Lugnutz65's Avatar
If you look carefully, you can see the saddles in this picture are in the LOWER position and would be correct for this narrow Harrison radiator.
Old 04-01-2014, 03:54 PM   #11
DPowers
DPowers's Avatar
Good info
Thread Tools
Display Modes
