Old 04-04-2014, 03:10 AM   #1
bh86
oil pan
im swappin a 5.3 4L60E into my 82 2wd. i've seen a lot of different oil pans used but i specifically wanted to know if the cts-v pan would work with the ac in stock location and not doing electric fans. Will i be able to move the motor far enough forward? Is it best to just cut the truck pan?
bh86 is offline   Reply With Quote
Old 04-04-2014, 12:33 PM   #2
Jmiller022
Jmiller022's Avatar
Re: oil pan
f body pans (98-02 Camaros) are real commonly used
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 04-04-2014, 02:43 PM   #3
bh86
Re: oil pan
Thanks for the reply jmiller. Do you know if one has more room than the other to move forward and back at the crossmember by chance?
Old 04-04-2014, 06:51 PM   #4
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: oil pan
He fbody pan has the lowest profile. I have one waiting to go on my lq4.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 04-04-2014, 07:26 PM   #5
chebyshortbox65
chebyshortbox65's Avatar
Re: oil pan
I'm pretty sure it will fit I have the complete set up from a 2011 erod engine haven't had the chance to check the fit but it should
chebyshortbox65 is offline   Reply With Quote
Old 04-04-2014, 11:03 PM   #6
crazy longhorn
Fabricate till you "puke"
Re: oil pan
Check my "69 longhorn ls swap pics", just a little down the page.I have some shots from underside, with the GMPP pan kit (Hummer H-3 pan). The nose of the chassis are very similar, between the trucks....& the pan kit was complete from Jegs for around 150 bones. It comes complete with gasket/hardware/pickup tube/windage tray, & dip stick for that money! You will loose a little capacity, but for a street dr, no big issue? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-04-2014, 11:59 PM   #7
littlevictories
Re: oil pan
http://www.jegs.com/i/Chevrolet+Perf...12593/10002/-1
this one? uses the new filter too. pretty slick.
littlevictories is offline   Reply With Quote
Old 04-05-2014, 12:40 AM   #8
crazy longhorn
Re: oil pan
Yes, that is the 1....takes a PF 48 filter. The pan holds 5 Quarts + filter. It might not be the ticket for a high RPM Bruiser, but should be fine on the street performance/cruiser, & the price fit the budget The pan does not hang below the crossmember, & has room to move, where you want your engine to 'set"....The caddy pan looked like a nice pc, & it would fit my app (slammed against the firewall), but the fit was good on the hummer pan, & the price was right on? Longhorn
Old 04-05-2014, 12:58 AM   #9
68c10airstream
68c10airstream's Avatar
Re: oil pan
Hi bh86, a very good bodyman friend told me many many years ago that the crossmembers from 67-87 would basically interchange. Yes tierod ends are different diameters through the years etc, etc, but my point is if a oil pan change works for 67-72 trucks, it should work for 73-87 trucks. Firewall style and location could impact you slightly, but there seems to be quite a bit of room. I installed a f body pan (98-02) and the forward edge of the pan in the sump area just touched the curved area of my crossmember but i'm running my engine and trans fairly low in the chassis. I'm using trailblazer ss factory ac compressor down low on pass. side and in the midst of mocking this system up now. Hope this info helps, good luck.
68c10airstream is offline   Reply With Quote
Old 04-05-2014, 01:27 AM   #10
crazy longhorn
Re: oil pan
Airstream, did you opt to cut the cross member for clearance on the F - body pan? Just a thought, I did that on an S-10/383, with an old style 6 q truck pan? Same deal, she was mounted low in the chassis... longhorn
Old 04-05-2014, 06:11 AM   #11
68c10airstream
Re: oil pan
crazy longhorn, yes i notched the crossmember with my sawzall, will finalize this when i pull the cab and gut the frame for total restoration
Old 04-05-2014, 07:19 AM   #12
crazy longhorn
Re: oil pan
....my brother! Sorry, I get a little excited, when guys are not afraid to cut what needs to be Longhorn
Thread Tools
Display Modes
