Flexplate question
Ok this may seem stupid but which flex plate is the correct one for a 67 with a 327 with the TH400.
It seems by looking it up that it is different than the other years and of course is hard to find. Can anyone help with this? ![]() |
Re: Flexplate question
Anyone?
![]() Join Date: Mar 2003
Any 168 tooth flexplate for an early model 350 that has the neutral balance. Maybe a starter if you have the smaller 153 at the moment
#4 | |
Thanks! |
It probably calls out the smaller 153. You could even use a plate off of a 396 or a 402 same as the earlier 2 piece rear main seal 350
I guess maybe thats it. I am assuming I have the 168 because my starter has the bolts diagonal not straight across. It would be nice to be able to use a FRA-100 they are pretty in expensive.
![]() Join Date: May 2013
If you had a powerglide , you will have the smaller 153 tooth flexplate , and will need to find a larger 168 tooth
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Sooooo, you have a 327 with a th400 already? What was the point of this thread? to see if the factory put it together correctly?
The point is that the teeth on my flexplate are shot and I was about to just go get one for a standard 2pc rmc sbc then when I tried to look it up the ones I could find were for all years except the 67. At that point I came here to check to make sure before I got a new one.
AHH, got it,, just take your existing with you and match them up. I doubt very much that there would be any difference. Could be just an edit problem in the book also
Watch out for your cornhole !
![]() Join Date: Jun 2003
you have a 2 piece rear main seal and staggered bolt holes on your starter so you need a Pioneer FRA-100 flexplate. Should be a common item at any parts store.
Autozone shows them for 20.00 O Reilly has it for 22.00
#13 |
#14 |
Compare the mounting holes for the TQ. There are some variations in them. Some TH400 use 6 bolts.
Thread Tools | |
Display Modes | |
