Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-14-2014, 01:20 AM   #1
Andy4639
Old member
Andy4639's Avatar
Talking Dash improvement
I had some issues with my dash so I decided it was time to look at it.
I also wanted to mount the new delay wiper mode also while I had the dash out. I got the brake light working and found my problem with the temp gauge and it wasn't in the dash it was out in the engine bay. The spade connector had come apart.
I got the delay wiper mod done to while I had it out. Not bad at all for a good nights work.
I still can't figure out why the oil and water temp go up when I pull the lights on though. Oh well at least it's all working again.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-14-2014, 02:02 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Dash improvement
The gages move when you turn on the lights because there's a voltage drop. Adding a relay to your headlights might help.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-14-2014, 07:01 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Dash improvement
Nope not the problem. Have relays installed and the gauges are going up not down. The volt gauge has a constant 14 volts on it. They go up with just the park lights on also. I took a jumper and grounded the headlight switch with the dash out but hooked up and it didn't change it.
Hawks put a ground from motor to cab wall and I added a motor to frame ground yesterday myself. Everything works fine just has that little gain when the lights come on so I know it's in the lighting wiring but where is the ?
Old 04-14-2014, 07:21 PM   #4
truckster
truckster's Avatar
It may or may not have anything to do with your problem, but the first place I check when dealing with electrical issues is grounding. Check battery to chassis, battery to body, body to chassis, under-dash, etc.
truckster is offline   Reply With Quote
Old 04-14-2014, 07:35 PM   #5
Andy4639
Old member
Andy4639's Avatar
I'm going to add a cab to frame ground to. Just to make sure it's all covered. A little more background on this just so if the right person see's this they may klick on something. I used the factory gauge cluster with Speed hut gauges(plastic) that just has the plastic collar holding them in place with all the grounds ran to the main ground in the back of the panel.
Old 04-15-2014, 07:19 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Dash improvement
Got the cab to frame ground cable mounted but no change in the way things work. Still have that little increase in oil and water when I pull on the parking lights are headlights. None of the other gauges are effected by this and the volts stay at 14 on the gauge. My scan gauge say the same thing 14 volts and it runs off the computer reading.
Old 04-15-2014, 08:26 PM   #7
engineer_gregh
engineer_gregh's Avatar
Maybe a bad light switch?
engineer_gregh is offline   Reply With Quote
Old 04-16-2014, 03:07 AM   #8
Andy4639
Old member
Andy4639's Avatar
I can't see how it would be bad when everything works correctly though.
Old 04-16-2014, 09:02 AM   #9
engineer_gregh
I hate electrical gremlins. The switch is an easy thing to try and one more thing to eliminate in troubleshooting the problem.
Old 04-16-2014, 09:08 PM   #10
Andy4639
Old member
Andy4639's Avatar
Can you explain to me what else I can do to see if the head light switch is the problem.
I stated I put a ground wire to it and it didn't make any differance so what else can I do to check it. The lights all work correctly also.
Old 04-16-2014, 09:55 PM   #11
engineer_gregh
Try another switch. If you need one I have a spare I'll send you.
Old 04-16-2014, 10:57 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a theory.
When you pull on the lights you get a voltage drop which is sensed by the voltage regulator in your alternator. That causes the alternator to kick up the voltage output which causes a tiny surge in the positive circuit of the truck. Higher voltage to the gauges will overcome the resistance in the gauges and show a higher reading on them until the alternator output levels out.
This would be more pronounced if the regulator was the old external type.
I would test this by turning off the lights and disconnecting the alternator small plug so that it would not charge. You'd be on battery voltage alone. Then turn on the lights and you might see a slight drop in the gauge readings but if they didn't increase with the alternator out of the equation, You might have your answer.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-17-2014, 02:36 AM   #13
ETsC10
Hand Crafted C-10
ETsC10's Avatar
MOVING TO ELECTRICAL....
Ellen
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 04-17-2014, 10:42 PM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: Dash improvement
I spent most of last Sunday going over all the dash stuff and I fixed several problems that I had. + installing the delay wiper stuff. I had the dash out that's why I was checking it. I used jumpers to ground the switches and the dash itself even with the one ground still hooked up + the ground in the bulk connector. I couldn't see any differances so I assume that it's else where in the electrical system. Where though is the $100.00 question.
VetteVet.
with the computer running the alternator now since the 6.0LSx motor install I'm not sure if I want to disconnect it while it's running. I have herd this can cause computer failures so not really wanting to try that at this point and time.
The increase seems to have gotten less since I added the 2 new grounds to the cab and motor but not real sure that's what did it.
Old 04-18-2014, 12:34 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I missed the part about the computer running the alternator so I agree with you. It's not worth taking the chance. I meant to ask you what the readings increase to, and do they stay constant or drop back down in a few seconds?
Both your gauges rely on sender grounding to the engine block. I don't see where you have your negative battery cable grounded. It should always go to the engine block for the best continuity for the starter and alternator and the rest of the grounds can come off the block.
VetteVet
Old 04-18-2014, 12:44 AM   #16
Andy4639
Old member
Andy4639's Avatar
The battery ground is to the front side of motor.
The gauges are now only going up a little not like before. Before the water and oil would peg out! Now they are just moving a little and will stay like that until you turn the lights off and as soon as you do they go back down which if they don't get any worse I can live with it. I added another frame to motor and frame to cab ground and it already had the cab to motor and motor to battery so I hope this has it some what fixed for now. Maybe some day while I'm doing another mod on it I will run across the full fix for it.
Oh the voltage gauge never moves it stays a good 14 volts all the time.
As always your help is greatly appericated as is everyone elses.
Thread Tools
Display Modes
