Old 04-15-2014, 12:03 AM   #1
bigrigpardo
cowl access
I have had an idea for cutting a hole near the end of the firewall under the cowl panel were the air vent it for easy cleaning and then making a bolt on plate to cover the hole. that way I can easily pull the cowl panel and have access to clean and paint if necessary down the road. anyone ever done this or something like it. it will also make repairing the cowl rust we all see under the hood easier. you wont see it at all with the cowl on but a couple of screws will make cleaning and maintaining a breeze
bigrigpardo is offline   Reply With Quote
Old 04-15-2014, 08:50 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: cowl access
I'm not sure I'm following you 100% but to clean the air boxes out I just remove the air vent doors and vacuum out the air boxes as good as I can, then blow them out with an air hose.
LockDoc
Leon
Thread Tools
Display Modes
