Old 04-15-2014, 09:12 AM   #1
c10Dream'n
c10Dream'n's Avatar
Going Under the Knife for Minor Surgery!!!
Finally got around to taking my truck to the shop to get my CPP C-Notch installed. Decided to have it welded in vice going with bolts. The welds looks awesome, and plugged holes as well. Can't wait to get it back in a few days.
c10Dream'n is offline   Reply With Quote
Old 04-15-2014, 09:32 AM   #2
engineer_gregh
engineer_gregh's Avatar
Re: Going Under the Knife for Minor Surgery!!!
What lowering kit did you use? Hows the ride compared to stock. Good looking truck!
engineer_gregh is offline   Reply With Quote
Old 04-15-2014, 09:59 AM   #3
c10Dream'n
c10Dream'n's Avatar
I used the ECE 4/6 kit, and I added 1" lowering blocks to the rear to eliminate the rake. It definitely needed the c-notch cause I would hit more often than not. I honestly think your always going to have a better ride at stock height. I previously had it lowered 2/4 and that ride was very nice as well, but I needed to go lower for personal preference. So now my c-notch is being completed and my next task is to get my exhaust rerouted cause that to is close to the axle and hits every now and then.
Old 04-15-2014, 10:08 AM   #4
engineer_gregh
Do you have pictures of the truck with the 2/4 drop? I'm considering lowering mine but I do not want to compromise the ride quality. I've not had an opportunity to ride in one that has been lowered. Thanks for sharing your pictures and experience.
Old 04-15-2014, 10:37 AM   #5
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I lowered my 67 3/5 and removed the factory bump stops cause they hit and replaced them with energy suspension short urethane bump stops and mine rides GREAT ! And I live in the most goofed up town in the united states of america as far as permanent never ending road construction its ABSOLUTELY RIDICULOUS ! They started building a few miles of 4 lane here in 1974 and THEY ARE STILL FRIKKIN WORKING ON IT ! The moral of this story is my truck rides good LOL
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-15-2014, 12:57 PM   #6
c10Dream'n
c10Dream'n's Avatar
Here she is with the 2/4...
Old 04-15-2014, 01:09 PM   #7
LUCKTRUCK
LUCKTRUCK's Avatar
don't forget, tires have alot to do with ride quality. 15's, 17's, 20's will all give a different feel
LUCKTRUCK
LUCKTRUCK is offline   Reply With Quote
Old 04-15-2014, 01:11 PM   #8
engineer_gregh
Thanks for sharing the pictures. I'm thinking drop spindles on front and 4" drop springs in the rear. I like the looks of 19673ontree and C10Dream'n with the 2/4 best. Will I have to relocate the rear upper shock mounts for the best ride? Just my opinion but it looks like 2/4 drop gives you some gap between the top of the tire and wheel well, and 4/6 puts the top of your tire inside the wheel well.
Old 04-15-2014, 01:13 PM   #9
engineer_gregh
Yeap, totally agree. I've got 8" rally's with 275x60x15 and they ride different than the Boss 338's with 275x45x20. The 20" ride better at stock height IMO and it gives me back some RPM's at highway speeds.
Old 04-15-2014, 02:04 PM   #10
19673ontree
CAN'T FIX NOTHIN
Yep I did the shock relocation brackets , I guess I bought everything cpp had for mine I put sway bars which makes it stiff but handles great !
underdash AC
Old 04-15-2014, 02:13 PM   #11
engineer_gregh
I just picked up a CPP front sway bar yesterday. It hooks to the a arms, does yours? If you think about and have a minute can you snap a few pictures of your front sway bar?
Old 04-15-2014, 05:48 PM   #12
19673ontree
CAN'T FIX NOTHIN
I found with the cpp front sway bar it had two sets of brackets for the frame if you use the short ones the pitman arm rubs the bar I suspect without power steering it might not ? So I used the two tall brackets and it worked perfect ,,, I will snap a pic ,,
underdash AC
Old 04-15-2014, 05:58 PM   #13
engineer_gregh
Thanks. A picture is always helpful:-)
Old 04-15-2014, 08:05 PM   #14
c10Dream'n
c10Dream'n's Avatar
Here's a pic of my CPP tubular control arms with CPP away bar. I got the shorter brackets
Old 04-15-2014, 08:10 PM   #15
engineer_gregh
That really looks good! You've obviously invested a lot of time, effort, and money into your truck. It looks great.
Old 04-15-2014, 08:17 PM   #16
c10Dream'n
c10Dream'n's Avatar
I was fortunate enough to buy the truck complete and just added my own personal touches to it, thanks for the kind words.
Old 04-15-2014, 08:19 PM   #17
Gmcfolife
Gmcfolife's Avatar
Looks like nice work. I did the same to mine.
Gmcfolife is offline   Reply With Quote
Old 04-15-2014, 08:43 PM   #18
c10Dream'n
c10Dream'n's Avatar
Looks good gmcfolife.
Old 04-17-2014, 01:19 PM   #19
c10Dream'n
c10Dream'n's Avatar
Got my truck back yesterday and wow what a difference that c-notch made. Nice ride home, especially with my engine tuned up as well.
Old 04-17-2014, 02:28 PM   #20
chevy72blu
chevy72blu's Avatar
Looks like they did a great job. Beautiful truck
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-17-2014, 06:03 PM   #21
TexasLS1
TexasLS1's Avatar
Do you have any pics of your exhaust routing? Did you have to gut the pipes shorter or have them re-routed at the time you did your 4/6 drop? Looks great btw!!
TexasLS1 is offline   Reply With Quote
Old 04-18-2014, 08:05 PM   #22
engineer_gregh
19673ontree are you running the tubular A arms as well? Mine are stock and I'm not sure how to install the sway bar to a stock A arm. Advice anyone?
Old 04-18-2014, 08:30 PM   #23
CC69Rat
CC69Rat's Avatar
C10dreamin - that made a huge difference.. looks great man.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-22-2014, 10:11 AM   #24
c10Dream'n
c10Dream'n's Avatar
Thanks, I am quite pleased with the outcome.
I will try and get some pics of my exhaust. The plan is to reroute my exhaust through the crossmember to allow for more clearance, as well as having the exhaust dump out behind my rear wheels vice straight through the back under the rear bumper. With the current set up, my exhaust is about 3/4 of an inch from the pumpkin and rattles once in a while.
I wich I could help on the sway bar, but I didn't run one with my stock A-arms.
Thanks Chad, it was a long time coming to finally getting the c-notch done.
Thread Tools
Display Modes
