Old 04-23-2014, 07:33 PM   #1
kgmunro
Trans change
Just wondering if a TH350 is a direct swap in if my 67 c10 has a powerglide now.
kgmunro is offline   Reply With Quote
Old 04-23-2014, 07:49 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Trans change
Should be as long as the tail shafts are the same length. Tail shafts were 6", 9" and maybe some more. If the overall length is the same you should be good.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 04-23-2014, 08:04 PM   #3
69SCSS
69SCSS's Avatar
Re: Trans change
Besides the different length of the transmission, the driveshaft yoke is different. A driveshaft shop can swap it out and adjust the length if needed. Here's a pretty helpful diagram I found today that shows the different dimensions of GM transmissions.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 04-24-2014, 06:38 AM   #4
kgmunro
Re: Trans change
Cool, I was worried about the shift linkage location more than anything, but will give it a shot!
Old 04-24-2014, 08:35 AM   #5
67 chevelle
67 chevelle's Avatar
Re: Trans change
With a 6 inch tailshaft its a direct swap , yoke is the same on a 68 , not 100 % sure on 67 but 90% sure its the same . There are various kick down differences , your powerglide has a rod , turbo 350'S either have a cable or an electric kickdown , both very easy to adapt . If you have a column shift it will fit but the detent for low will be missing
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-24-2014, 02:01 PM   #6
MARKDTN
Re: Trans change
Powerglide, TH350, 200R4, and 700R4 all share the same yoke. TH400 is the only oddball.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-24-2014, 03:26 PM   #7
sambudo
sambudo's Avatar
Re: Trans change
good info to know
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Thread Tools
Display Modes
