Old 04-28-2014, 09:33 AM   #1
Old Glory
69 250 exhaust leak
Started my old 69 after sitting for 12 years and need to address a problematic exhaust leak between the manifold and exhaust pipe. As best I can remember I would tighten down the two bolts and after a short period of time, they would simply come loose and the exhaust pipe would slide down the bolts enough to cause a leak.
Any tips on how I can secure the connection? Are there special bolts and washers? Loctite?
Old Glory is offline   Reply With Quote
Old 04-28-2014, 09:57 AM   #2
geezer#99
geezer#99's Avatar
Re: 69 250 exhaust leak
Brass exhaust nuts!!
Google it.
Old 04-28-2014, 08:36 PM   #3
Old Glory
Google it.
Thanks geezer! No washers or loctite?
Any other suggestions greatly appreciated!
Old 04-29-2014, 11:52 AM   #4
Old Glory
Bump
Old 04-29-2014, 06:17 PM   #5
Avitech
Avitech's Avatar
Two brass nuts on each stud. tighten the first one on each stud until tight and the exhaust is secure and then tighten down the second set to lock everything down. Brass is used so that you can get it all apart down the road.
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline   Reply With Quote
Old 04-29-2014, 09:41 PM   #6
Old Glory
Thanks!
Thread Tools
Display Modes
