04-29-2014, 10:57 PM | #1 |
Sending Unit
If I swap to a 40 gallon fuel tank can I simply bend the arm from my 21 gal tank to make the float read 'full' for the new larger tank?
1971 K20 Suburban 2012 LS1500 4WD Suburban 2003 Honda Accord LX V6 (don't tell anyone) MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915 |
04-30-2014, 12:33 AM | #2 |
Re: Sending Unit
Reading "full" will not be the problem, because the sending unit will still be on the top of the tank. Is the height of the 40 gal tank the same as the 21 gal tank? If the 40 is taller (deeper), the float arm would have to be longer to move from bottom to top correctly. Bending it won't help. I'd be more concerned that the gauge be more accurate at "empty" than at "full".
It wouldn't be the first time I had to catch a ride to the next town carrying a gas can.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
04-30-2014, 09:42 AM | #3 |
Re: Sending Unit
If you swap to a 40 gal tank why not just get that sending unit?
04-30-2014, 09:44 AM | #4 |
Re: Sending Unit
A sending unit from a 73 up Suburban still reads 0-90ohm. I would just buy it. there pretty reasonable.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-30-2014, 10:07 AM | #5 |
Re: Sending Unit
I am having trouble finding a unit for a 40 gallon tank that reads 90 ohm. They all seem to be 95 ohm. Also, I already have a new sending unit for a 21 gal tank and I am a cheap bastard! As you know, being on the east coast, I can't simply walk into a junk yard and find a 40 gallon tank from the early 80s (which had a 90 ohm sender, I think) - they don't exist.
04-30-2014, 10:09 AM | #6 | |
Re: Sending Unit
Also, I am not finding that 73 up had 40 gallon tanks.
04-30-2014, 10:17 AM | #7 |
Re: Sending Unit
Found one that references 40 gal tanks in that year. Thanks Mario.
http://lmctruck.com/icatalog/csb/full.aspx?Page=145
04-30-2014, 08:32 PM | #8 |
Re: Sending Unit
No problem. The 0-90 ohm is something I learned on this forum when building my old short box and installing a 20 gallon fuel cell. I think GM stuck with that type of gauge reading to 1991 for sure not sure past that year. I wish I could get a bigger tank in my 68 suburban easily.
04-30-2014, 09:52 PM | #9 | |
The Older Generation
Re: Sending Unit
I bought a new Suburban in '73 and it had a 40 gal tank. LockDoc
09-02-2014, 05:13 PM | #10 |
Re: Sending Unit
So....the original sending unit, on the 21 gal tank, has only one outlet. The 1973 sending unit on the 40 gal tank has 3 outlets. What are the other outlets for and what should I do with them? Just plug them?
Actually, RockAuto only has the 4 outlet ones. http://www.rockauto.com/catalog/more...328&cc=1294062 So, one must be a vent line, which shouldn't be blocked...what about others?
1971 K20 Suburban 2012 LS1500 4WD Suburban 2003 Honda Accord LX V6 (don't tell anyone) MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915 Last edited by chewiebarker; 09-02-2014 at 05:25 PM. |
09-03-2014, 07:05 AM | #11 |
Junior Member
Re: Sending Unit
I used a '73 tank & sending unit in my '71 and just plugged the 2 extra lines. you need one for fuel & one for vent
09-03-2014, 04:46 PM | #12 |
Re: Sending Unit
Fantastic. Thanks!
01-20-2017, 03:11 PM | #13 |
Re: Sending Unit
In for the picture
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
Thread Tools | |
Display Modes | |
