Old 07-31-2003, 10:28 AM   #1
ucmydust68
fuel
changing wheel bolt pattern
hey i was wondering if there was anyway to change a 4x3/4 bolt pattern to a 5x5 for our trucks, i have a set of vette wheels that i would like to use on the 72'
ucmydust68 is offline   Reply With Quote
Old 08-01-2003, 09:11 AM   #2
Seon
Seon's Avatar
I think there are wheel adapters on the market, but I wouldn't use them. You could have the hub and rear axle's lugs removed, holes welded and redrilled to 5" BC and install new lugs. I think those are the only two options you have .
Seon is offline   Reply With Quote
Old 08-01-2003, 03:18 PM   #3
SCOTI
SCOTI's Avatar
Adapters come in high & low quality. Billet adapters are much better than the old cast style, so they're a good alternative.
I re-drilled my front rotors to a 5x4.75 car pattern (adapters would have added to my backspace which I didn't want), but because of backspacing requirements I did use billet adapters for the back. It was about $75 for the machining on the rotors & $165 for the adapters.
Remember, if/when you opt to re-drill . . ..... if you have to replace the drums @ any point, you have to get them re-drilled as well. With adapters you won't have to.
You can see pics of my truck w/the car wheels on the 78-87 board. Look for the heatwave pics post pg1 & 2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-01-2003, 03:58 PM   #4
ucmydust68
fuel
sorry im kinda slow, did you weld the wholes shut on the drums and the rotors and then redrill them, was heat a problem when you welded them? also will any shop redrill them or what kind of shop do i look for? and your truck is sahweeeeet, i love that color, i wouldnt change a thing!!!!! thanks alot for the help!
Old 08-01-2003, 04:01 PM   #5
ucmydust68
fuel
ya im really slow, i just re-read your post and saw that you used the adapters for the rear, sorry, where did you get them??? will they hold 527ftlbs of torque???? thanks
Old 08-01-2003, 04:41 PM   #6
SCOTI
SCOTI's Avatar
They're as strong as your stock hub . . .... will it hold 527ft/lbs? They bolt on just like a wheel so strength isn't an issue.
I purchased mine through Skulte Performance (I was under the impression he actually was making them. After I received them, I learned he is just a distributor). Try http://www.motorsport-tech.com/ . This is where mine actually came from. Or do a web search for 'billet wheel adapters'.
If you use a 7/8" or 1" spacer/adapter, you will have to get special lug nuts & trim your factory studs slightly. 1.25+" don't require anything special.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2003, 10:45 PM   #7
GMC69
GMC69's Avatar
Following the same line of question, I have a 69 that I am swapping the front suspension from an 83 pickup or a 78 pickup ( haven't decided wich one) wich are both 5 bolt and my rear will be 6 bolt. Would I be able to get the rear re-drilled to match the bolt pattern??? Then do you know what drums would fit or do I have to re-drill those too???
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 08-07-2003, 11:46 PM   #8
SCOTI
SCOTI's Avatar
You can get re-drilled axles from several aftermarket sources or if you know of a competent machine shop, they could prob do it. My vote would be replacement axles since they're usually stronger & have zero wear @ the bearing races. I got my 5-lug axles for my 68 beater for about $200 from Moser (30% stronger than stock + all new 1/2" studs already pressed in). For the drums, just use 72 & later drums from any auto parts place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2003, 11:55 PM   #9
GMC69
GMC69's Avatar
Thanks,
my next biggest problem is finding an aftermarket source here in Ontario canada, so I don't have to pay all the extra costs of getting it from the U.S.
Mike
2019 Silvedrado 4x4
Old 08-08-2003, 08:34 AM   #10
SCOTI
SCOTI's Avatar
Don't rule out the machine shop if it's more economical. I originally did my 67 that way & still have those axles/drums in my garage. I changed them to a car 5x4.75 bolt pattern. They welded up the stud holes & re-drilled them, then machined the hub to the correct dimensions, & finally welded/re-drilled the drums. It cost me $200 wayyyyyyyyyyyyy back in 90-91, but I was able to get it done locally.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2003, 10:37 PM   #11
Truckhead
18436572
Truckhead's Avatar
If you want the old axles redrilled let me know. A guy down here in VA did my 55' panel truck and they were perfect, he's been doing it for about 15 years so he knows his stuff. I think the cost was about a hundred bucks for the axles and brake drums together.
Truckhead is offline   Reply With Quote
Old 08-20-2003, 01:28 PM   #12
Hardrock2
A$$ deep into trucks
Hardrock2's Avatar
Hey guys,
Went to look at a project '68 truck about a year ago.
The guy was running a "car" 12-bolt out back with the 5X4.75 bolt patern.
It had 15X8 'Vette ralleyes all around, so I ask him "What's up in the front?"
He told me that he used early-mid '70's CHEVY VAN rotors.
They are 5X4.75................IF,IF they are from a G-10 series.
Evidently, they share the same bearings/races as the pickups?
G-20 series vans (5X5) are most common, but there are a few G-10's still in the yards, and most parts houses still stock new rotors for them.
Just a thought! A little yard shopping might save the cost of re-drilling "used" rotors, or new van rotors would be "fresh"!!
Mike
hardrock2
Hardrock2 is offline   Reply With Quote
Old 08-20-2003, 02:36 PM   #13
blazerboy72
You can get new g10 rotors at autozone for 29.99
blazerboy72 is offline   Reply With Quote
Old 08-20-2003, 04:25 PM   #14
boraxman
Keepin an eye out
boraxman's Avatar
o.k. im a little confused. I havent had my truck that long. its a '70 and im in the process of changing my rear axles to later 70s 5 bolt and am already thinking of the front disc conversion. What exactly is the bolt patteren on mid 70s 1/2 tons?
boraxman is offline   Reply With Quote
Old 08-20-2003, 04:47 PM   #15
Hardrock2
Hardrock2's Avatar
5 lug on 5" bolt circle...........(5X5; 5 on 5)
'71-'87 disc brake conversion.
Mike
hardrock2
Old 08-20-2003, 05:28 PM   #16
boraxman
Keepin an eye out
boraxman's Avatar
Old 08-31-2003, 03:08 PM   #17
gmtrucksaddict
yep someof the light duty early 70's 10 series vans used car pattern and 7/16" studs same as lighter RWD cars and s-10s and such like chevelles novas camaros (F and A body) but not the big caprices and oldsmobiles though(B-body)
also 1LE camaro rotors in the 90s were the large 12" diameter and are car small bolt pattern too, at 4.75"
but cost a bit more though. but are good conversion pieces
gmtrucksaddict is offline   Reply With Quote
Old 08-31-2003, 03:28 PM   #18
Hardrock2
Hardrock2's Avatar
gmtruckaddict
ZILLIONS of 67-72 Truck parts??
Hmmmmm!.............No wonder I'm having a hard time finding MORE!! LOL!
You must have snatched'em all up! Ha,Ha!
Where ya located in this fine state?
Mike
hardrock2
Thread Tools
Display Modes
