Inside dome light
Are any of you setting up a dome light to come on when you open the door like newer trucks do? How are you doing it and where did you buy it?
Thanks |
#2 | |
![]() Join Date: Mar 2007
Re: Inside dome light
You can probably find the thread on it if you search by threads I have started if you are interested. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
I kept the dome light and circuit stock. I added kick panel courtesy lights that are operated off of door switches using a relay set up for ground energizing. Look at this for how to make your dome work with the doors.
http://www.alanhorvath.com/54chevy/domelight_relay.php
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
check my build. i believe your hinges could use a similar bracket
no relays used. power to dome light, ground thru headlight switch or door switches bracket. easy peasy 1x6x.125 steel with 2 holes ![]() looking up to the hinge w door open ![]() w door closed ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() Join Date: Mar 2011
Hey Rico, couldn't get the pics you wanted to post on the PM, so I'm going to put them here, any questions let me know???...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
![]() Join Date: Jul 2010
If a standard door jam switch that was typically used on 68 and up trucks won't fit with out binding, try this switch (search 58-64 beetle). I used it on my burb 3rd door and the burb barn doors. Very cheap and works great. The ones in my bug have been working for over 50 years.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
I got a couple of PM's of where to find the switch. Here's one of many on Ebay:
http://www.ebay.com/itm/VW-INTERIOR-...24d072&vxp=mtr
[QUOTE=_Ogre;6671936]check my build. i believe your hinges could use a similar bracket
no relays used. power to dome light, ground thru headlight switch or door switches bracket. easy peasy 1x6x.125 steel with 2 holes I used the same bracket setup as Ogre, concealed and works great.
easy peasy
Thread Tools | |
Display Modes | |
