05-13-2014, 12:31 PM | #1 |
Stock gearing for '79 diesel?
Ever since I've owned Lester, the speedometer has been horribly inaccurate. At an indicated 90, I'm actually only doing about 60-65, which is roughly 35% off. I'm wondering what the stock gearing was for '79 diesels, and whether the PO swapped axles when the diesel died. There's no mention of a special axle ratio on the SPID.
EDIT: Though I can't be sure, as I haven;t checked, it feels like I have 3.73s currently.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
05-13-2014, 12:39 PM | #2 |
Re: Stock gearing for '79 diesel?
Attached.
Choices are 2.76 (std), 3.07 or 3.40 are optional. Some models used an external ratio adapter. Perhaps yours is one of those models and someone has removed it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-13-2014, 03:17 PM | #3 |
Perfect, thanks for the info!
Assuming the truck came with a 2.76 originally at this point...here's why: Indicated 75 is actually 55mph (1.36 times faster than actual speed) Indicated 90 is actually 65mph (1.38 times faster than actual speed) If that is the ratio we are working with (1.36-1.38:1), then it's reasonable that the axles now has 3.73s (1.36:1, in relationship to a 2.76 rear). Thanks!
05-13-2014, 03:41 PM | #4 |
Just here to tinker
What size tires are you running? If you have 3.40 with 31" tires, that should yield you around 2400 RPM at 65 roughly.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
05-14-2014, 10:18 AM | #5 |
Somebody either changed the gears or the trans. I have swapped plenty of transmissions that messed up the speedometer. I never bothered changing speedo gears but that's how you fix it.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Thread Tools | |
Display Modes | |
