Old 05-14-2014, 07:30 PM   #1
grs
best booster, master combo
Which booster, master, and proportion valve is the best. One that CPP sells cost $299.00. The one that Early Classics sell cost $429.00. They could be built by the same company. Some company's have a bigger mark up. I will bay more money to get the best, but I don't want to pay more, and get the worst unit.
grs is offline   Reply With Quote
Old 05-14-2014, 07:37 PM   #2
AcampoDave
AcampoDave's Avatar
Re: best booster, master combo
Grs, I run disc brakes with no booster at all on my short bed. I don't need to "stand" on the pedal to stop either, plus my engine compatment looks cleaner without it. Just in case you hadn't considered manual disc I thought I'd chime in with a third option.
AcampoDave is offline   Reply With Quote
Old 05-14-2014, 10:17 PM   #3
brokenspoke
brokenspoke's Avatar
I bought one from Speedway....I later found out its made by CPP.....They advertise its for the 63-66 chevy trucks....I installed it and all new brake linings, calipers, brake lines....The rear brakes lock up way before the front in a panic stop...I contacted speedway who had CPP contact me....CPP was NO help....They suggested that I add a adjustable proportioning valve.....CPP stated that all combination valves for disk/ drum are the same.....neither company was any help.....I bought a adjustable valve and still need to install it
brokenspoke is offline   Reply With Quote
Old 05-15-2014, 06:57 AM   #4
brokenspoke
Originally Posted by Sharps40 View Post
Drill the pedal to fix the rear locking. Mechanical pedal ratio is too high for power brakes, lower the ratio and youll be fine. See mu John Lee brake thread for details on the ratio fix. 15 minutes and it will be like totally modern power brakes. Even w proportioning valve, ya still gotta get the pedal ratio lowered a bit
I did and the rear brakes still locked up
Old 05-15-2014, 10:16 AM   #5
luvbowties
luvbowties's Avatar
Thumbs up Re: best booster, master combo
Had same problem on a '65 that had been converted to a dual system--drum-drum--using what appeared a stock 1967-8 mc and without a proportioning valve at all. Installing an adjustable proportioning valve on rear half of system cured the problem completely; took our time, tried multiple settings on a lonely, dry road until we got wheels stopping w/out locking up the rears. Been happy for ~2 years, now.
Sam
luvbowties is offline   Reply With Quote
Old 05-15-2014, 05:33 PM   #6
Sharps40
Rears may be pulled up too tight then or may need to really fine tune a prop valve. They really shouldnd lock unless yer on em in a bit of a panic or a real slick road.
Sharps40 is offline   Reply With Quote
Old 05-15-2014, 06:23 PM   #7
Snailed
Snailed's Avatar
They have no way of knowing what brakes you will have on your vehicle. It's hardly their fault. When ever you buy a combination valve it's just a wild guess since EVERYTHING matters...tire diameter, type of friction material F & R, vehicle weight distribution, tire size and compound, shock valving, wheel rates, pedal ratio, master size, caliper size, wheel cylinder size, etc...
Put the adjustable one in an fine tune your setup to meet your needs. I stopped using the "all in one" combination valves since they often not good enough. It's like putting a carburetor on 5 different engines and expecting all of them to be tuned perfectly. It just doesn't happen and likely none of them will run right.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 05-15-2014, 06:37 PM   #8
Indian113
Indian113's Avatar
Has anyone used a Power Brake booster and MC from a S10 on their trucks?
Indian113 is offline   Reply With Quote
Old 05-15-2014, 09:10 PM   #9
brokenspoke
I bled the brakes today.....After three adjustments with the adjustable valve i'm happy with my brakes.....30 dollar valve is all it took
Old 05-15-2014, 10:02 PM   #10
'63GENIII
'63GENIII's Avatar
For the last 4 years, I have used a CPP master and 10" "kit" power brake unit. Occasionally I would lose the front brakes. By the time I would get to checking them out, they would be working again. About 2 months ago, after losing the front brakes again, I broke down and took the master and booster off. They sat at a weird angle to the firewall, the master was leaking and it was just time to figure it out. I ended up going to O'Reillys of all places and getting a new booster and master (separately) from a '73 - up k30. I installed it with minimal work to the firewall (just a couple more holes). It now sits level, is better supported and the brakes work great like they should have all along. I will probably never buy another CPP product again after this experience. I do agree that the proportioning valve should be adjustable (still running the CPP one) and that the brake pedal arm had to be drilled to align the pushrod and get the ratio right.
I have seen manual disc brakes stop as well as power with little more effort than power...... and it does look way cleaner.
Good luck with your choice
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 05-15-2014, 10:15 PM   #11
grs
How do I know where to drill the hole in the brake pedal arm? What angle?
Old 05-16-2014, 12:10 AM   #12
'63GENIII
'63GENIII's Avatar
I can measure mine but IIRC, I just made it even or "inline" with the booster. I believe that I didn't have the right amount of travel to begin with.
Chris
'63 k15 long step
Old 05-16-2014, 12:50 AM   #13
Captainfab
60-66 Nut
Several of my customers that bought my brake booster bracket have used the S10 boosters. There are a few options with the S10 boosters. You do not have to use a S10 master on a S10 booster.
Old 05-16-2014, 07:46 AM   #14
Indian113
Indian113's Avatar
Thanks Capt. I like the looks of the S10 booster,I guess it is it's size. I'll have to order your bracket when I do my disc brake change.
Old 05-18-2014, 08:37 AM   #15
Leroy-B1
Good thread
Leroy-B1 is offline   Reply With Quote
Old 05-18-2014, 08:50 AM   #16
Sharps40
Awesome news! Great perseverance too.
Old 05-18-2014, 08:54 AM   #17
Sharps40
See post 27 and up of the attached for locating and drilling the Pedal Arm for power brake ratio reduction.
Basically, 1" CTC lower than the upper manual hole, straight thru left to right, its a 3/8" hole.
Check/reset your brake pedal free travel and final adjust the drums and off you go.
http://67-72chevytrucks.com/vboard/s...d.php?t=611577
Old 05-18-2014, 01:02 PM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
I ran mine for a while with manual disc brakes up front, until it just got to being too painful with a bad back. I added the single diaphragm booster from Master Power Brakes. The relatively small size makes for plenty of room in the engine bay, and pedal pressure is about the same as my Honda CRV. I don’t know how it compares to any of the other aftermarket boosters.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-18-2014, 01:04 PM   #19
tincan1966
tincan1966's Avatar
OEM replacement boosters from local auto parts stores work just fine and are a fraction of what all these aftermarket places are charging.
O'Reilly's offers a direct replacement with bracket for the '64-66 trucks for around $140 plus a small core charge if you do not have an exchange.
Pretty simple really. If sticking with drum brakes (like mine) you do not need a proportioning valve, but rather a distribution block, and one from a '67-68 Camaro works good and are not expensive.
tincan1966 is offline   Reply With Quote
Old 05-18-2014, 09:46 PM   #20
Jeff La
What year model year S10 boosters are they using?? Thanks for any info.
Jeff La is offline   Reply With Quote
Old 05-18-2014, 11:18 PM   #21
donthekawguy
donthekawguy's Avatar
I'm going to get a booster/MC for a 75 1/2 ton for mine. I'll spray bomb it and paint the MC with POR15. They are $115 for both.
66 shorty
donthekawguy is offline   Reply With Quote
Old 05-19-2014, 12:40 AM   #22
Captainfab
60-66 Nut
The '82-'02 S10 boosters are all interchangeable. Which one to choose depends on whether you need a dual diaphram or single diaphram. The S10 boosters are not the only boosters that are compatable with my booster brackets. There are many, many OEM boosters, several of which are listed in this thread, post #183
http://www.67-72chevytrucks.com/vboa...=339081&page=8
Thread Tools
Display Modes
