Old 05-15-2014, 01:17 PM   #1
Pappyx3!
Pappyx3!'s Avatar
To Finish or Not to Finish?
Some friends gave me some rough cut walnut they had to do my bed floor. I was thinking about getting someone to plane it for me, but after just laying it in the back of the truck to look at I'm thinking about just protecting the wood and leave the rough surface... Appreciate your comments!
Pappyx3!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 05-15-2014, 01:28 PM   #2
closer9
Re: To Finish or Not to Finish?
I'm not familiar with your truck, but if you don't have a show truck, and plan to use the bed for hauling I'd say leave it. It looks good.
closer9 is offline   Reply With Quote
Old 05-15-2014, 01:42 PM   #3
Pappyx3!
Pappyx3!'s Avatar
Here is a picture of the truck. PO seemed to have a Hot Rod picture in mind.
As for how I use it, my son and I have taken our trucks to couple of local car shows, It will never be a serious show vehicle. Mostly, driven just for fun. Worked on for enjoyment.
John 3:16
Old 05-15-2014, 01:52 PM   #4
1963chevyc20
1963chevyc20's Avatar
all i have to say is https://www.youtube.com/watch?v=_hHDxlm66dE
1963chevyc20 is offline   Reply With Quote
Old 05-15-2014, 01:53 PM   #5
1963chevyc20
just kidding. i would paint it black.
Old 05-15-2014, 01:58 PM   #6
Pappyx3!
Pappyx3!'s Avatar
That's something to think about...
John 3:16
Old 05-15-2014, 02:16 PM   #7
1963c-10
1963c-10's Avatar
Personally I'd just seal it as is.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-15-2014, 11:25 PM   #8
Turtleman
Turtleman's Avatar
Its your choice,, but I'd plan it smooth and seal it,, or stain and seal it if you want (WADCO Black Walnut is really dark).
The main reason for planing is to remove any edge that can be damaged and create access to moister behind your seal coat. Once moister is behind your finish sooner than later your going to have a finish coat failure.
Turtleman is offline   Reply With Quote
Old 05-15-2014, 11:42 PM   #9
60sIron
60sIron's Avatar
Plane it then paint it or stain it. But plane it.
60sIron is offline   Reply With Quote
Old 05-15-2014, 11:46 PM   #10
Vernski
If your not going to be out in the rain leave it un-planed it is your truck. But if you are going to brave the elements you need to plane it, stain it, then seal it.
Use a dark stain and wipe it clean enough to see the grain of the wood, that looks like really nice walnut so you want to be able to see it through the stain.
JMO...Vernski
Vernski is offline   Reply With Quote
Old 05-16-2014, 12:40 AM   #11
oem4me
Unfinished, ..really? If that's Walnut, it's very pretty wood with nice color and hard tight grain. Left raw it'll soon enough turn grey and be indistinguishable from lesser woods. Personally I like black beds on stocker trucks, but if using a semi-premium wood in a modified truck, I'd give it the attention it deserves.
Old 05-16-2014, 12:44 AM   #12
BigSix
That looks so much better than with the strips. I am guessing you want to bolt them down without the strips? How thick are the boards?
BigSix is offline   Reply With Quote
Old 05-17-2014, 10:27 AM   #13
Mackie
Mackie's Avatar
If you use the truck and park outside you're essentially dealing with a deck. 22 years operating a paint store I can tell you the most complaints were on deck product failure. Nice clear walnut like that would look sweet finished and clear coated on a show truck but out in the sun and weather a "coating" will soon look shabby and turn into a maintenance headache. You could use a deck stain product ( builds no coating just soaks in) but most all are made for soft wood/pressure treated so won't penetrate the hard walnut. There are some made for hardwood like teak and mahogany. If you go this route you should treat the entire board -bottom, sides and especially endgrain- before install.
Mackie is offline   Reply With Quote
Old 05-17-2014, 10:50 AM   #14
Greg63
Enjoy your truck
Greg63's Avatar
If it were my truck, and wood, I would finish it.
I used marine varnish on the oak in my bed - 6 coats, sanding between coats) and it looks as nice now as it did 10 years ago when I finished it. You would have to coat every surface though.
If you plan on hauling anything, put a moving blanket over it. That works for me.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 05-18-2014, 05:56 PM   #15
Pappyx3!
Pappyx3!'s Avatar
If I had bought material to put in it I would have probably bought treated deck boards and stained or painted them...
but, I think you guys are right. The walnut material deserves to be finished and treated properly. I'm checking with some friends that are into woodworking to see if I can find someone to plane it for me. Thanks for all the comments!
Any good tonneau cover ideals for our trucks? Only thing I have been able to locate was a hard cover that was around $1500.
John 3:16
Thread Tools
Display Modes
