door weatherstripping
Would someone be as so kind as to post a picture of there tf door weather-stripping please I was reading a brothers tech article and I'm thinking have mine n wrong my door shuts cherry without it but after installed my door sits uneven thanx
Re: door weatherstripping
Look at Denee's thread. In it there is a good discussion on the weatherstripping with pictures.
http://67-72chevytrucks.com/vboard/s...d.php?t=471975
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I just did mine this week. My doors were jacked up until I put the new ones in. Now they close great. I will take a pic when I get home. What exactly do you want to see?
One good tip I got from the instructions was to make sure that the curved part goes toward the body. Also, I got the really thick weatherstripping at first. I had to order another kind because the thick stuff wouldn't let the door close correctly and it bulged out from the door gaps. Looked terrible. Looks great now that I got the right stuff in there!
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
no luck on that thread but it was some good reading I'm looking for pix of the out part door weatherstripping that goes around the whole door. I thought the big piece went against the door but I read that it goes opposite just want to double check before I get neck deep in it
on the brothers website it says this is the incorrect way to do it. is this right or ?
![]() Join Date: Jul 2010
^That is indeed the wrong way. The weather strip needs to be swapped to other door and vise versa.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
![]() ![]() Join Date: Nov 2008
The easiest explanation is that if it looks right, it isn't!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Heres a pic of mine from the same angle.
mine is on the wrong way all this time also , it dont leak or rattle been like that 6 years ,
I switch it ended up with more issues lower passanger sticks out and when I try to shut drivers door I have to slam the h-e double hockey sticks out of it
And a chip on the drivers side like the door shifted after I put the gasket in
That sucks. That happened to me when I tried to adjust my passenger door hinges. :-( Big chunk of old body work came flying out.
Thread Tools | |
Display Modes | |
