title question
Iv got another question for you guys im rebuilding my 72 and ran into alot of rust damage in the cab and today i came across a 72 gmc with a perfect cab what i am wondering is since the vin numbers are in the cab do i have to use the gmc vin or can i change the door jam plate and keep the vin of the truck im restoring? Thanks
Rusty Nuts
Re: tittle question
If you use the 72 GMC cab you use the 72 GMC title, swapping vins is frowned upon in a lot of states, or say illegal.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Re: tittle question
Legally, the VIN goes with the cab. It is illegal to remove the VIN plate from the door jam. Whether you choose to follow that is up to you...
I removed my VIN plate when my truck was painted.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
![]() Join Date: Sep 2007
Re: tittle question
And those daisy rivits are hard to find. I need 4 myself
1967custom |
Re: tittle question
Thats what i was afraid of my truck is a 72 chevy swb and the cab is either a 71 or 72 gmc long bed so if i used that title it wouldnt match my truck right? I could always cut and weld the parts i need but its alot more work and a bit over my experience level
Re: tittle question
Hmm maybe a door jam transplant
Re: tittle question
laws vary greatly from state to state. You can always ask questions at the local registration place.
![]() Join Date: Aug 2008
Re: tittle question
Fyi there are slight variations between 71 and 72 cans such as the inside rear view mirror mount and accelerator pedal mount.
Re: tittle question
Re: tittle question
Its too bad the easy way isn't the legal way.
______________________ ~ Jimmy: ![]() 69 C10 2wd Stepside PS, PB, .30 over 350, 700 R4, 4/6 static drop, aftermarket underdash AC |
![]() Join Date: Apr 2013
Re: tittle question
Been there done that, in Texas I had the title to the frame and a sales receipt from a salvage yard for the cab, bed, engine etc. When I took it for inspection at TxDot they used the frame numbers because of the title matching it. And the documentation that when to Austin list the cab numbers on it there. They installed a sticker next to the cab vin plate documenting that it is inspected and legal.
It's no big deal about the cab vin plate being from a longed truck, GMC or whatever the variables are.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#12 | |
Re: tittle question
#13 |
Re: tittle question
It's called title washing. Boyd Coddington narrowly escaped a prison sentence for doing it. If you get caught you not only lose the truck but you get free meals and housing courtesy of the state you live in.
#14 |
Re: tittle question
I cant give you legal advice. However asking on this or any other forum isn't the proper way to obtain legal advice. I would check with local authorities. Whatever you do make sure its legal.
#15 |
Re: tittle question
The crappy part about doing it legally is I think a deal fell through on me selling my truck because I did it the legal way through DOT. He questioned what the sticker was about and I told him, and then he went cold on the deal. He wanted to see the title which I didn't have with me, to see what it looked like. BTW it is a clean title not a salvage title.
#16 | |
Re: tittle question
#17 |
![]() Join Date: Sep 2010
Re: title question
I asked on here a little while back about the Rosette Rivets to remove/replace the VIN plate on my 67... What I found out was shocking... Even though I wanted to just R&R the vin plate to paint it, It is illegal in all 50 States... Even possessing the rosette rivets is illegal and you can be arrested on criminal charges... so I am painting around the VIN Plate...
From all I can see the information tlcrz1972 gave on changing the cab pretty much is the way it is in all 50 states... ALWAYS check with the state you live in to make sure you don't make a error that can cost you your truck... Also in buying one of these trucks that have been put together from several trucks make sure it can be titled in your state... These are just my experience/ opinion and your thoughts may be different...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 Last edited by 70cst; 05-24-2014 at 08:20 AM. |
#18 | |
![]() Join Date: Feb 2001
Re: title question
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#19 | |
Re: tittle question
Well I have the title in my possession it was just at my house in a safe and the day he was looking at it was just not possible to just drop what I was doing to go to town and get it. And he was a little on the questionable side anyway (wishy-washy).
It was no excuse, it was just put away so it didn't get lost or destroyed by any circumstance. Quote:
#20 | |
Re: title question
Thread Tools | |
Display Modes | |
