Old 05-27-2014, 09:56 AM   #1
Cabnchassis
Bypassing glow plug controller
Can someone direct me to a good write up on bypassing the sorry excuse for a glow plug controller on my detroit? Once the truck warms up once for the day the controller no longer functions, thats assuming it even decided to come on at all. My moms suburban controller works slightly better but not too much.
I've looked around the web but haven't seen a clear concise set of directions for bypassing. I was hoping to just run them off a momentary switch.
Thanks in advance for any advice you guys might have.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 05-27-2014, 10:58 AM   #2
mrolds88
Re: Bypassing glow plug controller
Everything I have seen has been done with a F*&d type starter solenoid wired in with a push button. Pull the power cable and the cable going to the glow plugs off your card and install them on the large terminals of the solenoid and then run your control wires. They make 3 and 4 wire variations of those solenoids. A 3 wire needs a good ground through the case in order to work. The 4 wire does not as the 4th wire runs to ground.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-27-2014, 12:10 PM   #3
D13
D13's Avatar
And swap to 60G glows and add 10 sec more on time. I use the factory timer a a guide when the beast is cold, when the dash light clicks off I keep the toggle on for 10 more secs.
I took the Ferd part and bolted it on the intake bolts from the (removed) EFE/EGR solenoids. Power from the HOT side of the controller, to solenoid, power out to the glow side of the controller. Used like 4awg lawn mower battery cable (fit the solenoid anc controller studs), ends crimped and heat shrink tubing sealed. Use a ground wire form #4 to the intake stud too. Then ran 2 small wires for ferd part thru hole in firewall, put momentary toggle under dash out of leg's way. Connected feed to hot side of controller, thru switch, then back to ferd ON terminal. Under #50 and allows the 60G self limiting plugs which need 5-10 secs more on time but will not swell.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-27-2014, 11:31 PM   #4
Cabnchassis
Perfect. I'm going to try to do this next weekend. I'm sick of these stupid controllers deciding when they want to work or not.
The glow plugs have been in my truck for ages any tips on getting them loose without breaking one? Just penetrating oil and a socket?
Old 05-28-2014, 03:00 PM   #5
hatzie
Moderator
hatzie's Avatar
The 91 should have the more reliable glow controller. I agree on the AC 60G Positive Temperature Coefficient glow plugs. They're more reliable and swelled glow plug failures are unusual with the 60G plugs.
There's a thermal glow-inhibit switch that has probably failed on your rig. Easy fix to get back proper controller operation. Look in my sig for the 1991 R/V series service manuals...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-29-2014, 09:28 AM   #6
Cabnchassis
Awesome. I'll check it out tonight. I've been looking for a service manual too, thats a huge help.
Thread Tools
Display Modes
