05-28-2014, 12:12 AM | #1 |
Need help ASAP !!!
So I spent the last two days at my parents, 150 miles from where I live, I went to head home tonight and oil starts pouring out of the top rear of my motor, I had just left made it a few miles and I smelled oil burning, worse than I'm used to smelling in a 42 year old truck(72 c20 350 4spd) so I pulled into an oreilyys auto parts in case I needed oil I get out and smoke is every where I look under the truck there's a puddle of oil, I look on top of the motor and see it pooled on the intake and running down onto my bellhousing starter and exhaust. Today I set my dwell on my points and my timing tightened the distributor down, and might have messed up by pullin the vent tube from my breather out of the valve cover and sticking an oil plug from my factory valve covers into the hole someone pointed out it could have cause pressure to build in the cranckcase causing oil to escape where it could, my ? Is where is it coming from, my oil sending unit is 3 months old, and would it build too much pressure even with a funtioning PVC valve in the other cover? I'm going to do what I should have at first and buy a new grommet for the breather and put it back but I'm not sure what else ill have to do now
05-28-2014, 12:32 AM | #2 |
The Older Generation
Re: Need help ASAP !!!
It might have blown the gasket between the intake manifold and the rear of the block out, or one (or both) of the valve cover gaskets in the back. LockDoc
05-28-2014, 12:44 AM | #3 |
What about the oil pressure line? Where it bolts into the block on the drivers side of the distributor. I had a leak like that a few years ago, sure made a heck of a mess
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
05-28-2014, 12:49 AM | #4 |
Pcv can't work without the breather, they are part of the same system. If you plugged your breather then you do not have a functional pcv. This is prolly you problem. If you lucky you just blew your oil out your valve covers and need to replace your valve cover gaskets which could have dumped onto your intake. Don't drive without some kind of breather. Your gonna have to find the sorce of the leak to know where it blew.
05-28-2014, 12:54 AM | #5 |
Moderator
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-28-2014, 01:01 AM | #6 |
It doesn't seem to be the valve cover gaskets, but it was dark and all I had was a crappy flashlight it's mostly pooling on the passenger side near the distributer and Im wondering if it blew out the little o gasket under there
05-28-2014, 01:17 AM | #7 |
If it's a large volume of oil, in a short time, it's probably your oil pressure line. If you need to get home, you can remove the oil pressure sender fitting and plug the block. I think it is 1/8" pipe.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
05-28-2014, 01:44 AM | #8 |
Moderator
Fix your PCV. Clean the engine thoroughly. Fire it up and watch for leaks.
05-28-2014, 07:28 AM | #9 | ||
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-28-2014, 09:21 PM | #10 |
I put it all back like it was drove it a few hrs then drove it 150 miles and itdidnt leak
05-28-2014, 10:05 PM | #11 |
That's good man, must of been the breather. I would still clean it good and keep an eye on it though.
05-28-2014, 11:30 PM | #12 |
I didnt know I needed the breather and pvc. See thats why I subscribe. I was gonna bypass my breather too.
1967custom |
05-29-2014, 12:02 AM | #13 |
I had no clue either, I'm glad I know now, I'm definately gonna watch it and check the oil at any chance, I have 42 years of build up what's the best way to get it off
05-29-2014, 12:11 AM | #14 |
Moderator
POR Marine Clean will take off 40 years of caked on crap.
05-29-2014, 12:12 AM | #15 |
A scraper some muscle. And if you cleaning up the frame outsise. Cheap oven cleaner after you scape the gunk. Then a power washer
1967custom |
Thread Tools | |
Display Modes | |
