Old 05-28-2014, 07:58 AM   #1
Blacksunshine87
Driveshaft ????????
I have an 85 swb 2wd with 350/700r. My question is that I bought a th400 short tail tranny and was wondering what truck/ car to look for to find the proper driveshaft length for a donor. Thanks!
Blacksunshine87 is offline   Reply With Quote
Old 05-28-2014, 10:55 AM   #2
Rich84
Rich84's Avatar
Re: Driveshaft ????????
Measure to see what length you need..Then go to the junkyard, they usually will have them in one area where you can start measuring.
I found that a crown Victoria police cruiser aluminum drive shaft was the exact same length as my shortbed.
Rich84 is offline   Reply With Quote
Old 05-28-2014, 12:45 PM   #3
Blacksunshine87
Thanks Rich84!!
Old 05-28-2014, 02:49 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Get a drive line out of a LWB truck, measure the distance that you need and have the longer driveshaft cut down and balanced at a shorter length.
Frank
piecesparts is offline   Reply With Quote
Old 05-28-2014, 08:54 PM   #5
ChevyGearHeads
I would go to
A-1 Driveshaft in Baltimore
1642 Beason Street
410-752-3000
We had one cut for my '68 long bed after putting a 350 Turbo in it and I was very satisfied with the quality and service. I took a few different routes and wish I had just went in the first place, junkyards are more or less a waste of time.
Paul
'68 C10 327/TH350
LWB
ChevyGearHeads is offline   Reply With Quote
Old 05-28-2014, 10:19 PM   #6
Blacksunshine87
Thanks guys for the info. I do not have the th400 in the truck yet. I know my driveshaft will have to be longer in length. I was just thinking someone on here had run my set-up sbc/ short tail th400 and knew right away what shaft out of a certain car/truck would work without installing it first. But from the sounds of thing I'll go to my local yard to find a longer shaft and have it cut down. Although the crown Vic driveshaft sounds interesting since I'm going to be using a 2004 front cradle from a crown Vic. Thanks again for everyone's input.
Old 05-29-2014, 03:37 AM   #7
andrewmp6
I gotta ask why are you using the crown vic front suspension?
andrewmp6 is offline   Reply With Quote
Old 05-29-2014, 08:04 AM   #8
Blacksunshine87
I got the idea from watching gas monkey. The crown Vic cradle is aluminum bolt in unit with bigger brakes and rack and pinion steering all in one. I'd save a lot of weight , better steering and more braking power.
Old 05-29-2014, 10:16 AM   #9
DREAMER1
DREAMER1's Avatar
^^^pics?
DREAMER1 is offline   Reply With Quote
Old 05-29-2014, 08:10 PM   #10
Blacksunshine87
http://67-72chevytrucks.com/vboard/a...1&d=1401408252
Old 05-30-2014, 02:03 AM   #11
frank69
Just a reminder the t400 uses a bigger yoke than a t350 or a 700r-4
frank69 is offline   Reply With Quote
Old 05-30-2014, 09:04 AM   #12
andrewmp6
You know its 5x4.5 lug pattern right?And your truck is a 5x5 unless you changed the rear end in it.
Thread Tools
Display Modes
