Old 05-29-2014, 08:14 PM   #1
brawley
Easy Does It
brawley's Avatar
Side marker light ideas??
on my 68' the side marker lights are just reflectors..curious what other options besides factory...looking for smooth reflectors that will fit factory openings...any ideas ..options..pics. thanks
brawley is offline   Reply With Quote
Old 05-29-2014, 08:43 PM   #2
SS Tim
SS Tim's Avatar
Re: Side marker light ideas??
There were the van style markers. Chevy "G" van from 85-96 IIRC.
SS Tim is offline   Reply With Quote
Old 05-29-2014, 08:51 PM   #3
brawley
Easy Does It
brawley's Avatar
that looks nice! thanks
Old 05-29-2014, 08:58 PM   #4
SS Tim
SS Tim's Avatar
Nice thing is being a back fitted factory part you can just buy a replacement lamp from so many places. It isn't my truck but it does look nice.
Old 05-29-2014, 09:55 PM   #5
BigMike
BigMike's Avatar
Could always go with Firebird lights. I've got a set I was gonna use but my brother used my idea so I decided to go another route and just shaved them.
Here's a picture of his truck, it's a really clean look.
Mike
BigMike is offline   Reply With Quote
Old 05-29-2014, 11:18 PM   #6
67ctener
67ctener's Avatar
These are from Marquez and look great IMO. I'm sure typically used in lighting applications but would work as reflectors
67ctener is offline   Reply With Quote
Old 05-30-2014, 12:23 AM   #7
SS Tim
SS Tim's Avatar
There really isn't a good reason not to make the side markers light up. Its an easy connection to the nearest park lamp.
Old 05-30-2014, 05:08 AM   #8
BigMike
BigMike's Avatar
Wish I could afford the Marquez tail lights, those things are BADA$$!
Mike
Old 05-30-2014, 12:54 PM   #9
big mike71
big mike71's Avatar
Soky classics Euro marker lights are cool, But I can't post a link.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 05-30-2014, 02:09 PM   #10
BigMike
BigMike's Avatar
Here ya go: http://sokyclassics.com/product.php?skcid=1002310
Old 05-30-2014, 02:15 PM   #11
67swb72klb
67swb72klb's Avatar
those from the vans should be available at a dealer still I bought a set a couple years ago
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 05-30-2014, 05:31 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Side marker light ideas??
Originally Posted by BigMike View Post
I have these on the 71 and lovam' They light up good at night. I want people to see it good so they don't run into me. They look good to. A lot of stuff looks cool but doesn't perform well, so I try to find both when looking for parts.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-30-2014, 09:42 PM   #13
outlaw 3454
outlaw 3454's Avatar
ebay !!!!
outlaw 3454 is offline   Reply With Quote
Old 05-30-2014, 10:55 PM   #14
DreamRyder1963
DreamRyder1963's Avatar
Do those lights sit flush with the fender like the G lights or do they stick out like the stock ones?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 05-31-2014, 08:50 AM   #15
Andy4639
Old member
Andy4639's Avatar
Talking Re: Side marker light ideas??
They stick out but not as far as stock.
Old 05-31-2014, 09:14 AM   #16
brawley
Easy Does It
brawley's Avatar
Like the options, thanks for the ideas, anyone know how the firebirds hold in place?? do they snap in -looks like no screws
Old 05-31-2014, 12:41 PM   #17
big mike71
big mike71's Avatar
Somebody on here was making those firebird ones for awhile. I don't know if they still do.
Old 05-31-2014, 01:16 PM   #18
FirstOwner69
FirstOwner69's Avatar
Search the forum from the search box at the top of the page for "Firebird markers ". You'll get many threads. Here's the 1st that popped up when I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=262363
FirstOwner69 is offline   Reply With Quote
Old 06-01-2014, 05:34 AM   #19
stsalvage
Scrapper 1
stsalvage's Avatar
Been trying to find out if i can get the rear side marker lights to flash when i turn on the turn single light Most people fill in the holes i like them there my self
stsalvage is offline   Reply With Quote
Old 06-01-2014, 08:57 AM   #20
flashed
I also have the Euro ones from SOKY on my truck ,they are bright and look great ,I love them.
flashed is offline   Reply With Quote
Old 06-01-2014, 10:13 AM   #21
Andy4639
Old member
Andy4639's Avatar
Easy enough to do. You will need a double filment bulb with socket though to have marker lights and blinkers. The wiring will stay as is and just add the rear blinker wire to the second element.
If you just want it to blink the take the feed wire loose of the park light switch and hook into the turn signal wire.
Old 06-01-2014, 08:22 PM   #22
74baggedbug
Factory mounted from behind.. I know the brass bolts aren't correct but it's what u had on hand
74baggedbug is offline   Reply With Quote
Old 06-03-2014, 02:09 AM   #23
BigMike
BigMike's Avatar
Firebird lights have tabs on the backs of the metal surround that go right where the stock lights go with very little modification. Then you use little nuts (the kind that holds side molding in) to tighten them. Also uses same type of bulb
Fit is fairly flush if not a little sunk in.
Name:  FIREBIRD Driver Side at low angle.jpg
Name:  FIREBIRD Driver Side.jpg
Name:  FIREBIRD side by side back.jpg
Old 06-03-2014, 07:40 AM   #24
Timborees
Thanks for this Andy, not to hijack, do you (or anyone else) have a photo of this done? and where do you purchase the socket from?? Thanks
Timborees is offline   Reply With Quote
Thread Tools
Display Modes
