Transmission Kickdown
Have 72 chevy with a 350/400. I don't have the transmission kick down set up. Does anybody know where I can get one? Also a picture of how it is set up under the dash.
![]() Join Date: Jun 2014
Re: Transmission Kickdown
if its like my th350 kickdown, then it doesn't hook under the dash. it's a cable that runs from your carburetor linkage near the throttle cable down to your transmission.
I'm having trouble with mine currently. I'm assuming that if it's similar to the th350 trans, then you must have a plug or something capping where the cable goes into the trans otherwise you'd be leaking fluid all over the place |
No it is an electronic button down by the gas pedal, at least that is what the transmission shop told me.
ahhh ok, yeah I just googled it....seems it is a switch.....sorry....you learn something new everyday!
![]() Join Date: Jun 2005
Check the parts board. 71-72 both used the same set up, but only on TH400. It is a switch that is activated by the pedal arm coming iinto contact with it. Prior to 71 it was a switch that was mounted on the intake that the carb linkage activated. You could use either style, but the gas pedal must have the provision for it if you use the 71-72 type, and they are probably easier to find than the earlier type. Good luck in your search.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Watch out for your cornhole !
![]() Join Date: Jun 2003
A few years ago I was putting together a truck with a TH400 and like you had no parts for the kickdown. I wound up using this kit....
http://www.lokar.com/product-pgs/thr...s/th400kd.html It's not the cheapest, but it works super slick. You mount the cable to the carb like a TH350 would have, and the electrical box to the trans pan bolts underneath the truck. Like all. Lokar stuff, its of the highest quality and made in USA. Don't know if stock appearance is vital to your build or not but it's something to consider.
Thanks for the information.
American Autowire sells the harnesses, I think Brothers or classic Industries carries them also, switch too.
![]() Join Date: Dec 2011
Hi a seller named Roger Koop (I think) set me up with an excellent TH 400 kickdown switch and harness. Switch bolts in a accelerator pedal, one lead goes to TH400 and the other lead to fuse box and I think pigtails to the radio lead.
Nice set and easy in. Lokar also makes a Th 400 kickdown that bolts to trans and runs to carb. Bought them both but went factory. search the parts board. Good luck dave
Love my wife, daughter, dog and truck. The more money you make the less happiness you have. My Build: The Little Tiger http://67-72chevytrucks.com/vboard/s...d.php?t=630564 |
Thread Tools | |
Display Modes | |
