06-08-2014, 11:26 PM | #1 |
LS Swap cold air intake... just a little custom
Like a lot of folks we just ran some tube with a cone filter for the intake. Due to space constraints the filter was on 12" of 4" tube with a 90 and 120 placing the filter next to the passenger fender. Needless to say it sucked hot air. Finally got around to redesigning the intake to be a true cold air system. Believe it or not this forum actually has some of the best threads on the topic with Andy4639 excellent pics here.
Using two 12" 45 aluminum tubes, a 90 silicone elbow, and a couple silicone connectors I rerouted the intake over the alternator and down into the empty space behind the core support on the drivers side. My father inlaw then fabbed a 4" metal punch based upon smaller models like these. This allowed us to cut a hole through the core without too much paint damage nor the need to remove the grill. Finally using aluminum sheeting I fabbed a cold air box and lid, polished the outside, and insulated the inside. Truck already runs noticeably better with the longer and straighter tubing. Cold air should help further. Here are the pics. Still need to get some better weather seal and some real world testing of the air flow.
71 C-20 Custom Camper California Truck |
06-09-2014, 12:54 AM | #2 |
Re: LS Swap cold air intake... just a little custom
Brilliant work!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
06-09-2014, 01:38 PM | #3 |
Nice job!
06-09-2014, 04:17 PM | #4 |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
06-09-2014, 07:44 PM | #5 |
I'm curious, what did you use for insulation? I was thinking of doing something very similar except making it out of f'glass instead of aluminum. Nice job!
11-20-2016, 09:44 PM | #6 | |
11-23-2016, 04:24 PM | #7 |
Old member
Our motor compartments look very similar.
Other than the colors!
Thread Tools | |
Display Modes | |
