what kind of gears in my housing?
I have a 82 Silverado. When the rear is off the ground and I spin one tire the other tire travels opposite. I would like to get posi but I need the truck for the street. What do I have now? Also what do I need for the street but no one wheel wonder? Thanks.:metal
Re: what kind of gears in my housing?
"Most likely" in an 82 you have a 10 bolt with 2.75 or 3.08 open diff.
You can remove the rear cover and count the teeth on the ring and pinion then divide one into the other to get your gear ratio. You might find the tooth count stamped on the ring gear.
John 82 Chevy Silverado 350ci/TH350 ![]() |
You can also count how many revolutions your driveshaft turns for one rotation of your tire. Simple math.
RIZ |
You can go to gm heritage.com and see what that truck came with and then do the spin deal
i count 12 bolts on the housing cover. whats that tell me?
From what I have read, they stopped putting 12 bolt rear ends in trucks in '81 so it might have been swapped from a 10 to a 12 at some point. You need to count the teeth or spin the wheels and count the revolutions of the yoke to find out what ratio you have.
How do you count the revolutions of the yoke?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Jack one rear wheel off the ground. Put transmission in neutral. Turn the wheel two turns exactly. Count how many times the yoke turns as you turn the wheel twice.
Looks like I have a 2.63 gear ratio. 43 and 16. What does that tell me? Im not sure how gears work. Confusion to me. If I upgrade to a Eaton posi unit which one do I buy?
my dad recommends a 4.11. What do you think and when can I get one decent price? Thanks. Last edited by westpoint; 06-14-2014 at 04:53 PM. |
4.11 is pretty steep. It will deliver a big jump off the line but not very good fuel economy. 2.63 (43/16=2.68) will deliver better fuel economy (assuming it is not bogging/lugging the engine) but will be a dog off the line.
For all around street use I like a 3.73-ish when I have an overdrive trans, or a 3.42-ish when the highest gear in the trans is a straight 1:1. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
What do you plan on using the truck for? What motor, tranny, and tire diameter do you have or plan on having? All these things and more play into picking the right gear ratio.
#12 | |
Im looking to keep the truck tire size and stance close to stock. Right now it has a 305 in it. I would like to put a bigger motor in it eventually or just increase the horse power in the 305. I will be using this truck to drive everyday. 10 miles one way to work plus errands. Hope that helps. I have another dilemma.... I removed the drive shaft. I also remove the front of the differential where the seal cap, bearing and race are. How do I remove the race? Do I need to remove all the gears in the housing to replace the race for the new bearing? Thanks for all the help. |
#13 | ||
Thread Tools | |
Display Modes | |
