Old 06-11-2014, 09:24 AM   #1
dmartin1
dmartin1's Avatar
new wheel bearing STILL CLICKING?
driver side front wheel began clicking on my 82 stepside. i jacked the truck up spun the wheel no clicking. no play back and forth bearing was tight and good.
no clicking while turning and moving either.just straight and it would go up and down faster and slower i went in the truck.
i pulled the wheel and took it all apart. it has newer timken bearings and races all greased well.
i tapped the old races out and installed new with new timken bearings that are ridiculously packed with grease.
reinstalled everything, about 50 miles later its clicking AGAIN.same thing.
did i not tighten the nut that holds the spindle/hub on tight enough?
i tightened it until it started to grab then backed off barely a hair to get the cotter pin in. is this wrong?
any help will be appreciated
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 06-11-2014, 10:09 AM   #2
Dead Parrot
Re: new wheel bearing STILL CLICKING?
Any chance you have a nail, rock or other weirdness in that tire?
How are the brake pads? Might be the noise maker that signifies you are near end of life for the pads.
Dead Parrot is offline   Reply With Quote
Old 06-11-2014, 11:56 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Try a different wheel. Had centerlines that clicked like a bearing.
Put rally's on it quit.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-11-2014, 01:24 PM   #4
cadillac_al
Brake pads?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-11-2014, 02:50 PM   #5
dmartin1
dmartin1's Avatar
the rotors are pretty new and very nice so im gonna do some new brake pads and inspect it all while at it again, and check the tire as well. if that doesnt do it ill swap the wheel and see if it stops. at the least itll have brand new brakes lol
i thought the brake pads near end of life would just squeal? do they make a tick?
65 nova
And more
Old 06-11-2014, 02:53 PM   #6
dmartin1
dmartin1's Avatar
when i go to stop, the front pads ARE squeaking as well. hmm?
65 nova
And more
Old 06-16-2014, 08:50 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
the squealer can rust off,don't depend on them to tell you when to change the pads.
do you have wheel covers?some can pop,when rolling,a little tape on the nib can help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Thread Tools
Display Modes
