Old 06-14-2014, 06:09 PM   #1
westpoint
rear brake drum stuck
Well it moves a little...lol. tapped with hammer and lubed. The e brake cable broke but I can pull and push cable with no help. Any suggestions?
westpoint is offline   Reply With Quote
Old 06-14-2014, 06:13 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: rear brake drum stuck
bigger hammer and also you can try to get a screwdriver into the hole on the back to move the adjuster lever and adjuster
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-15-2014, 09:42 AM   #3
cadillac_al
Our high school shop teacher said to just get a bigger hammer. It will either come off or break. I seem to remember carefully grinding the heads off the pins once to remove some drum brakes.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-15-2014, 01:25 PM   #4
cable666guy
cable666guy's Avatar
Like old Rusty said...screwdriver through the backing plate slot, and back off with the adjuster.
cable666guy is offline   Reply With Quote
Old 06-15-2014, 04:51 PM   #5
Cabnchassis
Try the backing plate if you can, but even if you smash it off with a sledge you aren't very likely to break anything that costs more than a few dollars.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 06-15-2014, 04:58 PM   #6
Gumby
Gumby's Avatar
if its really stuck good, big hammer and a sharp chisel and crack it, drums are cheap.
Gumby is offline   Reply With Quote
Old 06-15-2014, 07:49 PM   #7
Jake Wade
Jake Wade's Avatar
Back off the adjuster and spray some Kroil,PB blaster, etc at center of drum where it slides over axle.
It is more than likely hanging on the shoes. The shoes wear a groove in the drum over time and you have to back way off on the adjuster for the drum to clear the shoes.
Jake Wade is offline   Reply With Quote
Old 06-16-2014, 08:35 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
back it off and 5 lbs sledge,hitting it up, down,left, right
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Thread Tools
Display Modes
