Old 06-15-2014, 09:26 AM   #1
CST10
CST10's Avatar
Best adjustable stock mount trac bar?
Hello all,
It's been asked before I am sure but I can't seem to find the answer in the search function.
I lowered mine 3 inches in the back. It is slightly off side to side by 1/2 inch now in the rear. What or who has the best adjustable trac arm bar available using the stock mount locations out there?
Thanks for your help folks.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 06-15-2014, 11:46 AM   #2
67ctener
67ctener's Avatar
Re: Best adjustable stock mount trac bar?
Whoever you go with I'd buy a double adjustable bar. Way easier to adjust then the one sided adjustable. As far as stock location I haven't seen one. I think 3-4"+ drop you need to relocate them to the passenger side
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 06-15-2014, 12:28 PM   #3
J kippin
J kippin's Avatar
I have dropped mine 4.0 inches. I have a CPP but have relocated it to the lower passenger side. to keep a slight angle to it. They say with 3.0 you don't need it but I have used the same CPP bar in the past located to the passenger side. Fortunately I was able to reuse my stock U Bolts from the factory they came out with out any issues. Yeah I was surprised about it.
If you don't have a rear sway bar it may be a good time to install an IROC bar in there now. Search the site they had a great write up at one time for it and it sits cleaner than any other bar out there. Its no big deal to mount a couple 1.0 spacers, drill 4 holes, 2 3.0 heavy duty U clamps. Mount everything where you want it then tack weld he saddles to the clamps onto the axle tubes.
Upgrade the front to the 1.25 front bar from a mid 80's truck it is a complete bolt in.
J kippin is offline   Reply With Quote
Old 06-15-2014, 03:26 PM   #4
michael bustamante
michael bustamante's Avatar
Cpp has a stock mount adjustable bar for like 55.
E bay also has the same ones
1967custom
michael bustamante is offline   Reply With Quote
Old 06-15-2014, 04:53 PM   #5
CST10
CST10's Avatar
Thanks for the sway bar info. I have not done that yet. I'm have to look into the ccp trac bar. Is it double adjustable?
MyToys:
Old 06-15-2014, 08:57 PM   #6
J kippin
J kippin's Avatar
I don't believe mine is I would go outside to check but its dark out....and I am afraid of the dark LOL I will check for you later.
Old 06-15-2014, 08:59 PM   #7
J kippin
J kippin's Avatar
the article I have is How to Install a Camaro Sway Bar on Your Truck it was a 4 page article
Old 06-15-2014, 10:10 PM   #8
Lee H
Lee H's Avatar
Yes, the double adjustable does make it easier. But don't get to hung up, it's really easy to pull one side off to adjust and once it's adjusted you never touch it again.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-15-2014, 10:18 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
X2.
Seems like there's been a lot of focus recently on getting a double adjuster track bar. I do not see the point. Look at it this way, measure your truck to see how far offset the rearend is. Then remove the stock track bar and adjust the new one to length, taking account of the amount of offset you're removing. Then just bolt it on. You'll never adjust it again. It's not something you do repeatedly like changing your oil.
Old 06-16-2014, 02:28 PM   #10
J kippin
J kippin's Avatar
I did check on my rear bar. It is a single adjustable one. The only thing I would have done different would be buy one with the bend in it to better clear the rear cover. The straight bar works fine but does limit you on the removal of the rear differential cover.
Old 06-16-2014, 06:13 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 67ctener View Post
whoever you go with i'd buy a double adjustable bar. Way easier to adjust then the one sided adjustable. As far as stock location i haven't seen one. I think 3-4"+ drop you need to relocate them to the passenger side
x2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-16-2014, 07:26 PM   #12
DreamRyder1963
DreamRyder1963's Avatar
I just called CPP and Summit Racing and they said that the 6572DATB will fit in the stock location on a truck that is lowered 4" in the rear. The full colasped length is 23" according to CPP.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 06-18-2014, 09:36 PM   #13
CST10
CST10's Avatar
Cool. Thanks for the info. Since I don't have to much to adjust a single adjustable should work fine. Is it better to go with the relocated style or stock mount style with only a 3-4 inch drop in the rear?
MyToys:
Thread Tools
Display Modes
