Old 06-16-2014, 04:25 PM   #1
ACK
ACK's Avatar
Hole in Firewall for Clutch Linkage
For those with an automatic in your truck, how was the hole in the firewall where the clutch linkage goes through filled? I'm looking for a solution that doesn't involve welding and can't located a grommet with a 1-7/8 inner diameter. I'm leaning towards cutting an over-sized sheet metal circle, adding a ribbon of insulation, and screwing in place, but would like a prettier solution.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 06-16-2014, 05:11 PM   #2
Snailed
Snailed's Avatar
Re: Hole in Firewall for Clutch Linkage
Make your patch, paint it and glue it down. You could get away with using a high strength RTV or seam sealer on something like that if you don't have panel adhe$ive around. Even some double-sided tape for car molding would hold it.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 06-16-2014, 05:59 PM   #3
jtrichard
go to homo depot and get an 1 1/2" electrical box plug they fit 1 7/8" holes http://www.homedepot.com/p/Halex-1-1...0715/100197178
jtrichard is offline   Reply With Quote
Old 06-16-2014, 07:18 PM   #4
pimpston65
pimpston65's Avatar
good solution on the homedepot plug, i did find the oem "carplug" plastic cover from 4-5-6chevy trucks. paid $15 if you want original...
pimpston65 is offline   Reply With Quote
Old 06-17-2014, 01:17 PM   #5
ACK
ACK's Avatar
Thanks for the responses. Purchased the $1 Home Depot electrical box plug yesterday and it went in without a hitch. Some seam sealer plus paint and I can cross this one off the list.
Thread Tools
Display Modes
