Old 06-16-2014, 04:55 PM   #1
carryall
Steering column input
32" Stainless steel Raw Tilt Steering Column, Column Shift
This column features tilt as well as self-cancelling turn signals and four way flashers.
Works for column shifted 3 or 4 speed automatics. ( 3 and 4 speed indicator included. )
2" Column diameter and 1" DD Shaft, 2 1/8" Tall.
Do not have an ignition switch in the column so you will need to have a dash mounted one.
This is a universal column, it has no specific application. Modification may be required.
These are a 32" column measured from end of the D-D coupler to the end of the column itself (minus the steering wheel adapter).
Total length is 35 1/2" to steering wheel flange if you include the adapter.
Columns use a horn wire system and have a standard 4 1/4" male wiring harness, which was common in most GM columns '69 GM applications.
Come with 9 bolt style steering wheel adapter.
You can use different adapters depending on the style of wheel you have, they are easy to change and readily available, usually from the steering wheel manufacturer.
More Great Product Available at our store. Please visit Autonets
Ebay item number:271289329666
Does anyone know what quality they are and how they fit?
1967 Chevy Truck
1969 Chevy Panel Truck work in progress
1971 GMC 1500 all orginal
1972 Chevy Suburban brought from orignal owner
1984 Dodge Rampage 45,000 original miles
1992 Dodge D150
1994 Buick Roadmaster (LT1 Engine)
2000 Chevy Stepside Z71
2008 Honda Element
carryall is offline   Reply With Quote
Old 06-16-2014, 06:24 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Re: Steering column input
All ears on this one....
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Thread Tools
Display Modes
