Old 06-17-2014, 05:59 PM   #1
low n loud
292 l6 to a 5 speed?
Ok so I'm building a 63 c10. I have a 292 that has a lot more power coming from it. I've seen people suggest a nv3500 transmission but most people use it on a 250. The 292 has a little more grunt to it and I don't want to tear it apart in short order. I want to go with something that I don't need to worry about. I had a 3 speed, but I need to keep the rpm's down on the highway
This truck will be a driver. But will also be taken to the drag strip with my buddies.
Any suggestions?
Thank you
low n loud is offline   Reply With Quote
Old 06-17-2014, 07:34 PM   #2
pimpston65
pimpston65's Avatar
Re: 292 l6 to a 5 speed?
yeah send me all you unwanted 3 speed zbar parts and i send u a np205 granny gear 4speed... maybe a PG would fit ur bill. tame daily driver/then ball$ to wall strip beast!!!
pimpston65 is offline   Reply With Quote
Old 06-17-2014, 08:49 PM   #3
Sharps40
A granny 4 is the same performance and hwy rpm as the stock 3. It just has a near usless 1st and the same 1 to 1 hi gear.
To drop the rpm yell need either or both of an OD trans and differenr ring/pinion. A WC Camaro T5 would likely be okay rearward of a 292 I6 or go 200/700 R4.
Sharps40 is offline   Reply With Quote
Old 06-17-2014, 10:52 PM   #4
low n loud
I'm looking to keep a manual transmission now. But yes I need an over drive for highway use.
I have a bench seat. I wonder if the t5 would end up to far back?
Old 06-17-2014, 10:58 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Check out Sharps40's build thread...He put a T5 in his truck..He's gotta 250...The T5 outta a 1995 S-10 V6 chevy will work...all you need is the bellhousing adapter from Stovebolt.com and I believe a different crossmember and yer good to go...they are a nice fairly close ratio trans. How pumped up is your 292??? Here's a picture of my 292.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-17-2014, 11:20 PM   #6
low n loud
Do you have a link?
So far I have 500 4 barrel, long tube headmans, and hei distributor.
I going to order a cam this week. Over winter I plan to build a head for it while it snows. Love the inlines!
Old 06-17-2014, 11:44 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by low n loud View Post
Do you have a link?
I don't...I'll try an get you one though...Here's the picture of mine that I was talking about. I have a 600 edelbrock, short tube headers, hei.
Old 06-17-2014, 11:48 PM   #8
low n loud
What brand distributor or where did you get yours? Looks nice!
Old 06-18-2014, 01:12 AM   #9
Captainfab
60-66 Nut
The NV3500 should hold up behind your 292. While they are rated at about 300lbft, GM did put them behind the Vortec 350's and they hold up fairly well in that application. However you will have to change to a hydraulic clutch for the NV3500.
Old 06-18-2014, 02:09 AM   #10
Heater63
Heater63's Avatar
I wouldn't go with the T5, as you mentioned "drag strip". I thought about using one for mine, just as a driver, but after doing all the research, and even buying a couple T5's (you need a world class and then need a different tailshaft) I ended up selling them and buying a TKO-500. 5 Speed overdrive, all brand new, and will take 500 ft lb of torque. It's not cheap, but it's perfect.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 06-18-2014, 05:54 AM   #11
Sharps40
Agreed and per Tom Langdon, Stovebolts Engine Company, the S10 T5 is not the trans for abusive use as it was typically designed to run behind a 150"ish motor in a lighter vehicle and with a small motors amount of abuse. If I was going to occasionally drag, I'd use the World Class V8 Camaro T5 or find something different with an overdrive. Its too bad but many of the options will cost more than the truck + paint + engine!
Old 06-18-2014, 10:21 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Its a SpeedMaster GM HEI with a 65K coil....bruns all the fuel like nothing. lol I also didn't see you mentioned Drag Strip...No..the S10 T5 Transmission Will NOT be a good choice...It'd be better to purchase a Tremic 5 speed that will handle high amounts of torque.
Old 06-18-2014, 05:31 PM   #13
low n loud
Where did you buy it from? any special spacers for tail shaft reasons?
Old 06-18-2014, 09:37 PM   #14
low n loud
Anyone use a Richmond?
Old 06-18-2014, 09:38 PM   #15
Lugnutz65
Lugnutz65's Avatar
T.J. I don't agree with the 1995 S10 combo you mentioned above as a workable solution because it won't bolt up to his bell housing. A 1995 S10 T5 will have a FORD bolt pattern.
For the T5 transmission - 1993 was the last year that a Chevy S10 or GMC S15 had a T5 with a Chevy pattern case. From 1994 on, the T5s in S10/S15 trucks had a FORD pattern case. So a 1995 T5 will not bolt up to a 292 bell housing.
I also don't think that Stovebolt.com sells bell housing adapters.
If the OP wants a daily driver 5 speed OD transmission, then a T5 is an economical and practical option, but I agree that it will not take abuse.
If the OP decides to stay off the drag strip and will refrain from doing burnouts, then the world class T5 from a 1988 -92 Camaro or Firebird would be a good choice. Keeping the bench seat would require a tail housing swap. Going with bucket seats would allow him to keep the Camaro shifter position and keep the cable speedo connection too.
Adapter plates are only needed for the S10/S15 T5s and there are even ways to get around that.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-18-2014, 10:43 PM   #16
TJ's Chevy
TJ's Chevy's Avatar
Well...I think you missed one of my posts cause when I found out the guy was gonna go to the drag strip I let him know that the S10 T5 was not a good idea...also...yes..I know about the different years..I just get them mixed up once in awhile. lol And Langdon's stovebolt actually does sell an adapter...but not for this engine.
Old 06-18-2014, 10:52 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Nice thing about Richmond is that they are the chevy bolt pattern.....issue is they are spendy as heck...like them all...I've seen the Richmond Non-OD 5 speed Trans used....nice thing is its a close ratio trans...but yer gonna wanna nice OD trans if yer gonna stay with the stock gear ratio.
Old 06-19-2014, 10:43 AM   #18
Lugnutz65
Lugnutz65's Avatar
T.J. McCauley,
Well...I think you missed one of my posts.
Nope, didn't miss any. I read all of your posts.
. . . cause when I found out the guy was gonna go to the drag strip . . ..
OP said he wanted to use it on the drag strip in his first post.
. . . I let him know that the S10 T5 was not a good idea . . . .
We both agree a T5 will not take abuse. Not a good choice for drag strip use.
. . . yes..I know about the different years..I just get them mixed up once in awhile. lol. . . .
This was my point entirely. The year (1995) you mentioned will not work.
. . . And Langdon's stovebolt actually does sell an adapter...but not for this engine.
Yes, Langdon's Stovebolt might sell an adapter. However, you said stovebolt.com sells the adapters. That is NOT Langdon's web address. His web address is http://www.langdonsstovebolt.com/
Old 06-19-2014, 10:56 AM   #19
Sharps40
Old 06-19-2014, 11:51 AM   #21
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by theastronaut View Post
LT1 T56 is rated at 450 tq and will bolt up.
Gonna need bucket seats! lol!
Old 06-19-2014, 12:07 PM   #22
theastronaut
theastronaut's Avatar
Or just relocate the shifter. Can be done with a ball socket and linkage back to the original shifter, and it should fit under a factory high hump.
theastronaut is offline   Reply With Quote
Old 06-19-2014, 12:10 PM   #23
Lugnutz65
Lugnutz65's Avatar
And . . . . . drum roll please . . . . it can accept a cable speedo connection so you can keep the original instrument cluster if that's the "look" you want.
Old 06-19-2014, 01:28 PM   #24
Shaky
Six in a row makes it go...
Shaky's Avatar
I have a Richmond behind the 250 in my '66. It's not a hot engine though, and I put 3.08s in the rear.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 06-19-2014, 02:13 PM   #25
60-66
60-66's Avatar
I don't mean to hi jack this thread but since we have so many T5 Gurus here I have a few questions on this swap.
My Brother is replacing his stock 283 front mount engine and 3 speed mid mount at bellhousing in his 1961 X frame short bed. He's putting in a new GM crate 300HP 350 with stock 3:90 rear end gears and T5 shown below.
Question one, can he still use the same 61 bellhousing and mid mount ?
Two, looks like I'm reading he needs a hydraulic clutch, which he already has but what's different ?
Three, is drive shaft length different ?
Four, heres the trans he is using, can he use the original low hump or does he need the high hump and will it affect his bench seat with this shifter location ??
Any other parts or suggestions Id like to help him before it gets to involved.
Thanks !!
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Thread Tools
Display Modes
