Old 06-25-2014, 10:27 AM   #1
1963c-10
1963c-10's Avatar
What 60-66 models came with passenger side alternators
Need to order the final harness for my 63 sb step side BBC swap. I'm using a passenger side alternator and I know that most of the trucks came with driver side alternators. Trying to keep wiring to plug and play and I know there were some trucks that had pass side alternators, which would make wiring much easier. I know that I can use my existing harness and lengthen the wiring, but I'd rather use another factory style harness if possible. Thanks for any help.
Truck still retains the external regulator.
I believe the GMC v6's were pass side.......but were the GMC's external regulators on the driver side or passenger side?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-25-2014, 11:52 AM   #2
rideblue00
rideblue00's Avatar
Re: What 60-66 models came with passenger side alternators
really? ive never seen a pass side one ever. no need for it really. Maybe the big bolts then? got some pics?
rideblue00 is offline   Reply With Quote
Old 06-25-2014, 12:41 PM   #3
newbe351
GMC externial regulators were on passenger side (at least on my '66)
newbe351 is offline   Reply With Quote
Old 06-25-2014, 01:10 PM   #4
1963c-10
1963c-10's Avatar
Ive seen quite a few GMC's that have the pass side mounts. Ill dig up some pics. I'm running a LWP set up on my 427, hence the pass side mount.
Old 06-25-2014, 01:15 PM   #5
BigSix
GMC V6 alternator is top of engine passenger side with regulator just above it on the inner fender.
BigSix is offline   Reply With Quote
Old 06-25-2014, 01:16 PM   #6
1963c-10
1963c-10's Avatar
Couple of pics of the GMC alternators on the pass side...and if I had looked at the pic better the 1st time (the regulator on the firewall).
Old 06-25-2014, 01:20 PM   #7
MikeN
MikeN's Avatar
I've used reproduction wiring harnesses from M&H Electrical on both my 64C10 and my 69 Chevelle. Their products are pricey, but absolutely top notch. They also offer custom modifications, like internally regulated alternator, electric choke, HEI distributor, blade-type fuses, etc. I bet they could build a harness for your drivers side alternator. They have an online catalog, and their tech people are knowledgeable and easy to get ahold of on the phone.
MikeN is offline   Reply With Quote
Old 06-25-2014, 01:20 PM   #8
1963c-10
1963c-10's Avatar
So....so far no factory 60-66 chevy pass side alternators it seems. Might just be easier to modify the stock harness to accommodate the pass side mount.
If I go the GMC harness route, the regulator would need moved which is more work and I actually like the Chevy placement better on the radiator support.
I'll wait and see what else pops up here 1st. Thanks to all that have responded so far!!
Old 06-25-2014, 02:10 PM   #9
BigSix
Sorta off-topic but on rear drive platforms you will usually find the AC on passenger side, power steering on driver side, and alternator shoved where-ever it will fit. If you must put it on the driver side there may be a way to make it happen using some creative bracket work?
Old 06-25-2014, 02:29 PM   #10
1963c-10
1963c-10's Avatar
Brackets aren't an issue. I already have it mounted.
Old 06-25-2014, 04:12 PM   #11
Captainfab
60-66 Nut
There were no '60-'66 trucks with a V8 or I6 and a passenger side alternator. They all had short water pumps with a drivers side alternator. The long water pumps and passenger side alternators didn't happen until '69 in the cars and '73 for the trucks.
Old 06-25-2014, 04:20 PM   #12
1963c-10
1963c-10's Avatar
OK, Thanks Captainfab....kind of what I thought, but figured it was worth a shot.....hey, you never know unless you ask. I think at this point I'll just have to unwrap the factory harness and add some longer wires to the alternator.
Old 05-07-2015, 11:23 AM   #13
1963c-10
1963c-10's Avatar
Just a follow up on this and to share the info with everyone else in case anyone else runs into the same issue.
I contacted American Autowires who built my forward harness in 2009. I have sent the harness back to them to make the appropriate corrections to the harness so I can hook up the passenger side external alternator.
They do sell correct harness's for the passenger side alternators in both internal and external regulated though, although not listed on their website.
Old 05-07-2015, 01:01 PM   #14
AngryPirate
AngryPirate's Avatar
My 1960 GMC v-6 305 has the alternator on the passenger side as well as the regulator on the passenger side inner fender.
AngryPirate is offline   Reply With Quote
Old 05-07-2015, 01:08 PM   #15
1963c-10
1963c-10's Avatar
Thanks AngryPirate for the input on your passenger side alternator. Was just updating the thread.....someone else at some point will do a conversion or have a factory application that will need a passenger side alternator harness and just want to share at least the one place I found that has them. They will modify my harness and it'll keep the horn, horn relay and regulator in stock position, just modifying the length on the alternator lines.
I have to give 2 thumbs up to American Autowire also....they suggested sending the harness back as opposed to purchasing a new one. Much appreciated and a good cost saver.
Thread Tools
Display Modes
