Old 08-04-2003, 03:17 PM   #1
palallin
Manual Throttle
The dash in the truck that's donating its cab to mine has a manual throttle cable. When I disassembled it, I found that the plastic behind the metal bezel was a small piece about an inch square laid over the sirface of the dash panel itself. The little piece, which included the raised area with the raised letters on it, was not glued to the dash: it was simply held in place by the bezel.
Was this method of labelling the maqnual throttle SOP or did somebody hack up an original dash panel in order to put it through this one.
I should note that the option sheet lists the manual throttle as originally installed on the donor truck.
What I plan to do is drill a hole in my own dash panel (below the choke) and retain the throttle cable.
One more minor question: there was no provision for mounting the rearview mirror above the windshield (that is, no holes in the "headliner"), but the cab is a '70. There is no hint of anything having been attached to the windshield, either. Was it possible to NOT have an in-cab mirror?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-04-2003, 03:25 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
As for the throttle, it is factory correct as described. Trun your dash bezel over and you'll see its already stamped with a raised area showing you where to drill the hole.
I'd say it would be possible to have a cab w/o a RV mirror. Is it an original cab or could it have come from a cab and chassis which might have had a camper or box container bolted on the frame making the RV mirror useless.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-04-2003, 03:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In 69 the mirror was still an option, but i am pretty sure that it was standard in 70.
Old 08-04-2003, 06:57 PM   #4
1970cstblazer
1970cstblazer's Avatar
My 1970 Blazer has a factory manual throttle. The knob is mouted on the left side of the dash bezel under the headlamp switch. I have never seen another one like it.
1970cstblazer is online now   Reply With Quote
Old 08-04-2003, 07:09 PM   #5
Zeus
Zeus
Throttle Cable
How does the cable connect to the pedal or does it connect to the carb linkage?
jesusventura@hotmail.com
Zeus is offline   Reply With Quote
Old 08-04-2003, 08:16 PM   #6
Pardue'sCustoms
Pardue'sCustoms's Avatar
my truck has it and it connct to the pedle
Pardue'sCustoms is offline   Reply With Quote
Old 08-04-2003, 08:44 PM   #7
JimKshortstep4x4
Smile
We have a 70 and a 72 which had the factory throttle setup and they both connected to the gas pedal.
Jim
Old 08-04-2003, 09:27 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
There were 2 varieties, one for cable style pedal linkages and one for rod-style linkages. I had a 69 (rod style pedal linkage, not cable) and the hand throttle cable went thru firewall and attached to pedal linkage in engine compartment.
Old 08-04-2003, 09:36 PM   #9
Jwill41
Jwill41's Avatar
what is manual throttle for, early cruise control or are we talking about manual choke?
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-04-2003, 09:46 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Raises engne rpms to run PTO's, plow hydraulics, etc without having to be in cab. Definately not a redneck cruise control.
Thread Tools
Display Modes
