08-04-2003, 04:07 PM | #1 |
Post Whore
Tranny cooler and tranny crossmember ?'s
A buddy is putting a TH400 into a truck with a 283. The radiator is not set up to act as a tranny cooler also. Should he be okay if he just gets an external tranny cooler (passive, without electric fan) or would he be better off getting a new radiator with built in tranny cooler? The radiator he has is in good shape so it doens't need to be replaced.
Second question, he is trying to remove the tranny crossmember from a 1972 pickup and he is having difficulty getting the crossmember out of the frame. Does he need to break all of the rivets to get it out?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-04-2003, 04:21 PM | #2 |
ok first off yes the external cooler will be much better than using the one that would be in a radaitor. secondly is the crossmemeber moving or no? if it moves you have to push the passenger as far back as it will go and pull the driver forward it comes out on an angle
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-04-2003, 05:09 PM | #3 |
Only the rivits that are attached to the fram need to be removed. I had to use a deadblow hammer to get mine out due to the rust build up.
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
08-04-2003, 05:09 PM | #4 |
external oilcoolers cool much better than the combo with the radiator the down side is during the cold of winter the combo with the radiator warms the tranny fluid to correct operating temp much better
Thread Tools | |
Display Modes | |
