Old 06-28-2014, 06:27 PM   #1
davepl
davepl's Avatar
Broke my hazard switch
So I broke the little red hazard switch on my 1970 auto column. Rolled it around on a towel and I guess that was just too much for the old plastic.
Searching old posts, it sounds like you can't just replace the little red thing, you need an entire new signal switch too? And does that include the wiring harness that goes down the column?
I'd be grateful if someone could tell me what I need and where to get it! I went through the LMC catalog, but maybe it's called something other than hazard or flasher.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-28-2014, 07:30 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Broke my hazard switch
You are looking for a turn signal switch. I checked Classic Parts, LMC and Classic Industries catalogs with no luck. Here's one on eBay for a non-tilt column.
http://www.ebay.com/itm/1967-1968-19...7651b9&vxp=mtr
And for tilt-
http://www.ebay.com/itm/1967-72-Chev...3D111240144626
FirstOwner69 is offline   Reply With Quote
Old 06-28-2014, 07:35 PM   #3
69chevytrucker
69chevytrucker's Avatar
turn signal canceling cam is what the part is called you can get it at any part store cheap like dirt and the best thing the part has not changed in 40 yrs the one from a mid 80s is the same as a 69 70 etc AIRTEX / WELLS Part # 1S2023
69chevytrucker is offline   Reply With Quote
Old 06-28-2014, 07:37 PM   #4
69chevytrucker
delco #d6216
Old 06-28-2014, 07:38 PM   #5
FirstOwner69
Do those have the non-removable red knob?
Old 06-28-2014, 07:39 PM   #6
davepl
davepl's Avatar
69chevytrucker - none of those have the correct flasher button do they? They appear to be the one you screw the little male threaded button into.
LMC does offer it FirstOwner69 - page 155. But their drawing doesn't indicate whether it has the right style button. So I think I'll grab the eBay one since the pic shows it.
Old 06-28-2014, 07:43 PM   #7
davepl
davepl's Avatar
d6216 also lacks the button and uses a straight, rather than crescent shaped, connector.
Old 06-28-2014, 07:58 PM   #8
69chevytrucker
ya i think all the new one will have the screw in knobs but they work in a pinch
Thread Tools
Display Modes
