07-01-2014, 10:25 PM | #1 |
Cluster King
Speed Warning speedometer head F/S
I am thinning the heard a little.
This is a nice one. It is un restored but the mileage has been set to zero. All gears are in excellent condition and operation is very smooth. Very nice face and needles also. Comes as you see it. $200.00 shipped to you door insured. I can build a cluster to sell with this also. First, I'll take it gets it. Negotiations on this thread only. No PM's except for mailing and payment information please. Thank you for looking, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C Last edited by TBONE1964; 07-02-2014 at 01:08 AM. |
07-02-2014, 10:41 AM | #2 |
Re: Speed Warning speedometer head F/S
Hey Tom,
What is the "speed warning" actually used for? |
07-02-2014, 10:49 AM | #3 |
Cluster King
Hi Steve,
When the speed warning is hooked up in the cluster correctly, it will alert the driver that they have reached a predetermined speed. The white needle is operated by turning a knob n the cluster bezel that turns a cable that turns a set of gears behind the speedometer face that move the white needle. Once the speed has been reached, the normal orange needle grounds against the white needle and activates a buzzer mounted under the dash to alert the driver they have reached there speed. I hope I explained it OK but in a nutshell it is an alert to the driver that they have reached the speed they set it at. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
07-02-2014, 10:52 AM | #4 |
You explained it perfectly, thanks, I've always wondered about that. Is this a rare option? It looks great BTW..
07-02-2014, 11:03 AM | #5 | |
Cluster King
Thank you for the comments, Take care, Tom
07-08-2014, 12:00 PM | #6 |
Cluster King
ttt
07-08-2014, 12:26 PM | #7 |
"GO DAWGS"
Do you have the rear tin with the brass pin?
Thanks, PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
07-08-2014, 03:07 PM | #8 |
Cluster King
PT,
I will need to check my inventory. I am out of town currently. I need to check on one for too much stuff as he is also inquiring. I am also working on the idea of reproducing the brass pins and making my own speed warning tins. They are certainly the hardest part of the puzzle to get in good original condition. I will get back with you if I have any spares. Take care, Tom
07-08-2014, 03:26 PM | #9 |
"GO DAWGS"
The whole brass pin can be eliminated by cutting a hole and using a round rubber grommet then just run the S/W wire through the hole. The simple reason for the pin is to keep the whole system non conductive so it will work correctly. The only reason that most want the tin with the pin is it is the way GM designed it but I personally think it was overkill. I have built more than 50 of these clusters and you could come up with a pin that had threads on the inside part of the tin then the problem would be solved. The only thing about remanufacturing a part like that is once the big boys like Counterparts or someone like that knew that there was a market for this part and they mass produced them then they would blow you out of the water on the price. The Impala's and Camaro's used the same pin. I have robbed several pins out of 66,67,68 and 69 Impala clusters.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops Last edited by PT'S 70 CST; 07-08-2014 at 03:32 PM. |
07-08-2014, 04:56 PM | #10 | |
Cluster King
It would be very easy to make a pin that would work as the original and be able to keep the factory connectors on both ends. Something else on my list Take care, Tom
07-12-2014, 04:17 PM | #11 |
Cluster King
Saturday Afternoon Bump
07-12-2014, 04:39 PM | #12 |
Roadtrip!
What would it take to get this and the gauge tin from you? I have an NOS fuel gauge and an NOS temp gauge i would part with. (and a few used gauge parts)
I really can't believe nobody has jumped on this. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
07-12-2014, 05:06 PM | #13 | |
Cluster King
I will send you a PM. Thank you, Tom
07-12-2014, 05:13 PM | #14 |
Cluster King
This speed warning speedometer head sale is on hold pending a negotiation with too much stuff.
Thank you, Tom
07-17-2014, 10:40 PM | #15 |
( what all will need to be complete this unit )?
( just wounding if not to much i would like to in jump in line ) |
07-17-2014, 11:13 PM | #16 | |
Cluster King
Along with it, you would need the rear tin that has the grounding lug for the wiring, and the hole for the control cable, the control cable with the knob. I will be getting a speed warning cluster built for sale in the near future. To just buy the pieces to make your own are going to be around $300.00. You may find a used non tach speed warning cluster for sale for about the same price.
Thread Tools | |
Display Modes | |
